one-sixty 3-pt question
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: one-sixty 3-pt question
    Posted: 02 Feb 2012 at 7:10pm
I have a 160 with 3-pt problems, it will work when it wants to, but hasn't worked in the last 3 weeks. Changed fluid and filters with no help.
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 7:59pm
we had a 160 we used as our scraper tractor before we got a skid loader and it had the same problem. we fought that thing for a while , it would go up not down then down but not up. its been a while but i think we took the valve assy apart and cleaned it. then it worked for a while then started giving problems again. then we replaced the valve assy. after a while it started doing it again and thats when we sent it down the road..try taking the valve assy apart and cleaning it they can get dirty....Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 9:10am
One-Sixty's are famous for 3 pt hitches not working.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 1:44pm
Anyone know what is the issue (and fix) for 160's 3-pt problem?
TomSEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomSEOH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 4:15pm
Did you check the screen in the top of the tranny where the suction line comes out ?
