8x24 B/C four bump rims
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: 8x24 B/C four bump rims
    Posted: 01 Feb 2012 at 1:35pm
QuestionQuestions
   Were the 4 bump 8" rear rims the only OEM style rims available on Standard Bs and Cs after the C was put in full production in 1941?  Were the 8" rear rims, we rarely see from time to time, with the continious raised bead around the entire drop center a AC OEM too or just  another style  aftermarket replacement rim for Bs and Cs ?
   May be looking for a real good solid pair of "4 BUMP" 8 inch rear rims for the correct cloning of the War department B under construction near Austin TX.  Jim C is trying to get this special OD Green B as right as possible to replicate one of the 96 Bs the War Department bought to help us win WWII.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:13pm
The 4 bump were only used on the early B. The continous bump was standard for most of the production. I don't know when the change happened. My 39 & 40 B's had 4 bump but my 47 B has continous bead, along with both of my C's. Early B's & C's had an 8" rim and later ones had a 9" rim. Bob
Edited by Chalmersbob - 01 Feb 2012 at 10:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:15pm
I don't know if I ever saw a 4 bump rim on a C. Bob
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 10:28pm
Parts book shows a rim change in 1939 at tractor # B18055 but it doesnt say what changed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:32am
I'm quite familiar with the early B rim changes from the first split rims of 37 and 38 with their special clamps and the next change in 38 into 39 with no bumps used with 3/4 bolt footed clamps. Then on  to the 4 bump rims along about 1940 using the standard 5/8 bolt clamps used for the rest of production. I have seen the 4 bumps in widths of 6, 7 and 8 inches. Seeing those with the continious raised clamping bead has been a rare experience for me leading me to believe they were aftermarket replacements. I have never owned or worked on a B or a C with anything but the 3 I'm familiar with. I have a pile of junk 4 bumps off of parted out B and C  tractors but none with the continious raised bead.
   I find it interesting that the continious bead rims were standard on late production Bs and Cs and are no longer available new. Or are they? Don't guess I ever saw a 9 inch 4 bump either on anything I parted out.
   JimC  may be interested in trading the pair of 8" late production continious bead  for a pair of early production 8" 4 bumps.
