N62 rod bolts lock washers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: N62 rod bolts lock washers
    Posted: 31 Jan 2012 at 7:32pm
Where can you buy the lock washers for the N62 Continental rod bolts?And the pal nuts for main bolts? Thanks Tracy Martin
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 8:47pm
I know McMaster-Carr has Pal nuts. And many variations on lock washer. www.mcmaster.com
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 8:50pm
Gerald, I have not found a grade 8 with internal star locking. They are 5/16 diameter. Thanks Tracy Martin
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 10:04pm
I needed 1 and got it at the local hardware store. My mains didn't have nuts, it has bolts. Book states that they came both ways, changed by serial #. My local hardware store also has the palnuts. That stuff is in the pull-out tray boxes. Bob
Edited by Chalmersbob - 31 Jan 2012 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 1:10am
I see them not rated by grade, only by hardness and there is a heavy duty version
http://www.mcmaster.com/#91150A113 I don't know what the ASME standard that's referenced says about strength or plating. It would take a tough washer to cut into a grade 8 nut or bolt.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 1:19am
McMaster says their grade 8 bolts also meet ASME B18.2.1 like those heavy duty internal star lockwashers. But so do grade 5 and grade 2 bolts. Grade 8 bolts are said to Rockwell C33 hardness, while those heavy duty lock washers are C44 hardness.
Gerald J.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 4:14am
Check Gerard Moones Montes Equipment Chicago Illinois.  Sells parts for Connie engines.
