No Narrow Front B's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Topic: No Narrow Front B's
    Posted: 28 Jan 2012 at 8:13pm
For some reason I never thought about it until I read a post tonight about seeing a single wheel B. Some one corrected them saying it was probably a C. I then realized I never saw a NF B before. I take it A/C never made one. Seems odd for some reason.They made every other model either way.Or am I wrong.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 8:16pm
There was a narrow front "B" at the GOTO in Union Grove 2005.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 8:22pm
I think the reasoning is that a B would have been awful limited on row spacings with a narrow front end.
Just my opinion,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 8:34pm
I have one, until Steve and I rip the early C front end off it and put it back on his tractor where it belongs...
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 9:42pm
There were a few made..............but not at the Allis Factory.
Like the C tractor on e-bay now with the B arched wide front, it was real easy to
split the Bs and Cs and switch halves.
Tim8975 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim8975 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 10:07pm
The Model B was designed and marketed as a single row crop tractor whereas the Model C was wider and designed and marketed as a two row crop tractor. Only makes sense that a narrow front end on a single row tractor would not work out.
Tim
http://www.allischalmershistory.com (Work In Progress)
1959 AC Series 1 Black Bar Grille D17 Gas WF
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 10:38pm
Yeah, what Tim said. I believe DickL has one, but it is a sister to the one Glenn has(meaning it has an early C frontend under it).
Bs and Cs had several differences, despite sharing engines, hoods, transmissions, and some other components. They had different finals, different hubs(on earlier models), different fenders, and the radiator shroud. Also, the steering boxes were reversed. If you put a B steering box on a C, the wheels would turn left when you turned the steering wheel right. Would be vice-versa if you put C steering box on a B. Some folks found this out the hard way. That is one obstacle to overcome when making a NF B. You would need to change the steering box as well as the front end from the engine forward.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 10:44pm
There was NEVER a factory made narrow front B.  However, some have taken a C narrow front or single front and put it on a B.
As said above the B was a one row tractor.
Good Luck!
Bill Long
This page was generated in 0.146 seconds.
