where to get a set of liner orings for a model c
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Topic: where to get a set of liner orings for a model c
    Posted: 28 Jan 2012 at 7:48pm
im looking for a whole set of liner o rings for a model c engine, any one know where to get them? thanks for any help...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 7:50pm
After market sleeves or AC sleeves
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 7:53pm
      are your liners original ????[ we have new set a-c only]    m& w liners are diidifferent along with many others     1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 7:55pm
they are aftermarket i  bought a overhaul kit years ago and was getting water in the oil immediatley and found a bad liner oring. tore it down to clean it all up and want to put it back together now . i dont even remember where i got the kit...Jb
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 7:59pm
i really would like to find a running engine for it . the tractor is really nice but if i cant get the orings im kind of stuck. when i bought it the engine was in pieces i should have left it there...Jb
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 8:58pm
tAKE YOUR SLEEVE TO ANY PLACE THAT HANDELS ORINGS THEY CAN FIX YOU UP ,START WITH A LOCAL BEARING CO SOME OF THEM HAVE ORINGS, IF NOT THEY CAN TELL YOU WHO DOES, ORINGS ONLY COME IN A FEW GLAND SIZES , IN EACH SIZE THIER IS A VARIETY OF LENGTH FOR THE PROPER OD  TOM
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 9:01pm
Sandy Lake Implement  1-888-252-0656 or any of the advertizers on this site.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 9:50pm
I just went to Dads parts bin and got a set out a couple months ago.
I'm sure they would have restocked it by now.
The universal answer to all questions is yes, how much do you want to spend?
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 10:35pm
What is the difference between AC and aftermarket liners and o-rings?
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 11:27pm
some aftermarket used thinner dia...cross section
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 8:26am
i have bought both at McMaster Carr on line.. dont remember the numbers off hand, but your right , the MW were a thinner cross section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 8:37am
So the grooves in the aftermarket sleeves are smaller as in width and depth of cut?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 10:38am
YEP!!!!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 10:52am
You could do it strictly by measurement, but I'd recommend you pull the sleeve, and take sleeve AND an old O-ring in to the shop when you go.  Another suggestion is any place that does hydraulic seals and fittings- they typically have someone in their line-card that does such things, and as such, will be able to properly source the right ring material for the application.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 11:20am
If you haven't picked them up yet PM me your address and I will send you a set eight of them.
