All-Crop 40 cylinder bar question
shattercane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop 40 cylinder bar question
    Posted: 26 Jan 2012 at 8:31am
 Has anyone out there swapped out the rubber on a set of all crop 40 cylinder bars? I am wondering if I could take some baler belts, cut them down and use liquid nail or some form of caulking glue to hold them on. I was also curious if there was a strip or two of rubber inside the cylinder housing. I see two solid bars on the bottom of the housing, but they are only approximately 3/8" so attaching rubber to those could be interesting. Any information would be greatly appreciated...also if anyone needs oak parts for an ac40 I'm in the process right now so doing a few more wouldn't be too big of an issue.
Thanks
29 L Case, 37 CC Case,40 A-C allcrop 40, 43 B Allis Chalmers, 50 DC Case, 54 WD-45 WF, 67 190 Gas
Don M SEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don M SEIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2012 at 5:25pm
I have replaced all those rubber things,  part from Tom Yaz http://www.allcropharvestor.com/,  and bars from Gary Agrimson.  Don 319-572-0914
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 4:45pm
 Don, do you recal what you used for adhesive or did you rivet the rubber on? Also does the rubber on the cylinder bars sit flush with the edges? I'm looking for the most practical (not to mention cheapest) way to get this beast back in the field. I sent a message to the All-Crop gods to get their recommendations and prices if need be.
Thanks again.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 5:18pm
   I think Don means he bought the bars from Tom or Gary. He didn't redo his bars.
   Don, What does Gary have ? I don't see any All Crop parts on his site ?
http://www.rumelyallis.com
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 8:36pm
you might as well use tomato paste as an adhesive.the rubber is vulcanized to the cylinder bars.might ck aroung and see if you can find a company that does that sort of repair...
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 7:07am
I have always wondered if lagging that is used on drive pulleys for grain legs would work.  It is glued and bolted on the pulley.
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Post Options Post Options   Thanks (0) Thanks(0)   Quote shattercane Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 12:24pm
I'm going have to get creative on the bars, If my wife found out what a new set cost she would take half of my collection and sell it to the scrap yard to pour salt in the wound. I'm either going to try some serious adhesive with bolts every three inches or my sister runs a body shop and another thought that crossed the mind was having her vortex the bars which would be something similar to rhino lining. Does anyone have any pictures of the rubber that bolts down to the housing? It looks like it would have to have a 90 degree angle to it in order to do any justice. Thanks again for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 6:10pm
Let us know what you do and how it works. Keep us posted.
Thanks
Wil
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 6:32pm
On the 90 the concave bars were half round rubber.Don't need a 90deg angle to thresh
