Wd45 Wiring question?
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 Wiring question?
    Posted: 21 Jan 2012 at 11:08pm
Where do I run the coil wire to?  coil to 3 position switch.  I bought a new 3 position switch (steiner) and am wondering how to do this.  This is a 6volt system.  Also how do I wire in my push/pull on and off ignition switch?  the wiring diagram in my book is for a magneto.  Help very much apprecited.
thanks
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 11:48pm
http://people.clemson.edu/~wsmth/Elect/WD45w.htm
go to this site and look it over
and if you still have problem
ask away
HTH      B:-)    Dnoym
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2012 at 11:50pm
You'll need a different switch for the ignition coil. The magneto switch grounds the points to stop the engine. That WILL also stop the battery ignition engine, but will kill the coil and the battery if you leave it grounded. You need a switch that you pull to turn on and wire that between the ammeter load terminal and the coil supply terminal.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 7:37am
Would have to know more about the switch you bought. Is it a ign. switch or a light-charge switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 7:48am
Too bad they don't send a diagram with it. Steve at B&B will if you need it. The field windings hook to the 3 position switch so they go through the resistor when the switch is in, and are grounded when the switch is out. The lights connect so they are on when in the middle position. The coil MUST be wired to a separate ON OFF switch that has battery power to the other side. There is no direct connection from the coil to the 3 position switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 8:33am
There is a diagram on Stieners site for the 3 pole switch.
http://steinertractor.com/pdfs/ACS139_instructions.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 3:16pm
Awesome - with your explanation it kind of clicked.  I was missing the concept that the on/off switch needed power as well.  I guess the coil also needs power.  The switch I have will interupt flow to the coil.Thanks!!!!
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2012 at 9:57pm
Hook your OFF-ON switch to the generator side of the amp meter. 14 ga wire will be fine. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2012 at 9:12am
When installing that 3 position switch, be careful that none of the wires touch the inside of the box. I don't carry that switch, I sell the OEM Delco switch that was the main stream switch during mass assembly. Many of our customer's told me about how that aftermarket switch does not fit well in some of the ammeter boxes and how their harnesses got shish-ka-bobbed because of that. When running a Battery ignition, its always good to use a regular Ignition switch to control power. This way you have a switch that is designed to handle the power chores without being to light of a switch to cause problems in the wiring system elsewhere......
