D-15 Tail Light
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Tail Light
    Posted: 20 Jan 2012 at 9:21am
I need a replacement tail light for a D-15 series II and I am wondering first, what was original equipment?  What it had recently (until the housing broke Wednesday night) was a 4" diameter flat backed red warning light which I assume is an aftermarket item.
I use this tractor a lot at night for clearing snow and need something on back for my visibility when using the snap coupler blade.  Although the broken light was only a red warning light it did give off enough light to iluminate things in back.
In the future I would like to have something more along the lines of a work light.  I looked at Fleet Farm and there were two choices for generic lights; would you guys recomend a flood type light or a trapezoidal?
Also, I see on ebay a combination work light and warning light on ebay for JD tractors, but I cannot tell the mounting method (I need a stud on the bottom).  After looking futher I see Steiner has one with a stud at the bottom and a selector switch on top, does anybody have one of these?
Part of me would like to still have a warning light as the farm is on a major two lane highway, but I only have room to mount one light and if I can only have one I would prefer a work light.  Looking for thoughts and ideas, thanks for the help.
Mike
Edited by Michael (WI) - 20 Jan 2012 at 9:25am
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 9:31am
We had a combination light on our D-14 when I was growing up, worked great.  Work light / red combo...with the switch on top, single stud mount.
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 9:53am
Our D15 II is also a switched work/red.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 2:11pm
Thanks for the replys.  I ordered one up from Tony, we will see how it works.
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2012 at 3:23pm
Let us know how you make out with it. I need to rewire the lites on my D-15 II and I think im going to add some flashy lites. My rear lite looks ok but I dont know if it works or not. Brian S
