8000 series make 2wd into fwa?
orangepower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series make 2wd into fwa?
    Posted: 17 Jan 2012 at 9:31pm
can you take a 2wd 8000 series tractor buy front wheel assist from a salvage yard and make a fwa tractor? and whatever the rest of the hardware, just wanderd if there was a removable plate on 2wd drives to put drive shaft.
45 diesel puller, 45 gas puller, ca puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:44pm
No, the rear end housing is different. No side cover plate.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:47pm
The parts book list diff housing #'s  for 2wd & fwa....rear housing.Trans hsg same for 2wd & fwa,p/s and pd respectivly. Probably not
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepower Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:51pm
alright, shoot, thanks for the info.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 10:04pm
If only you could, then we might ask if we could add it to a 7045, 7060, and 7080 as well. And how cool that would be. Don't hold me to it, but I think it tells in Norms book that 7000's were built with extra room just for future plans of FWA. I might have to do some reading tonight.
