C carb question |
Goose
Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Topic: C carb questionPosted: 16 Jan 2012 at 10:09am |
Is there a way to find out what model Zenith carb is on a 48 C without taking the carb off?
There is a tag on the carb, but I'd rather not take the carb off just to read the tag. (The tag is at the back, against the block.) Edited by Goose - 16 Jan 2012 at 10:10am |
Texas B
Joined: 04 Aug 2010 Location: Pointblank, TX Points: 99 |
Posted: 16 Jan 2012 at 10:20am |
Mirror and flash light won't work?
Texas B 39
Goose
Posted: 16 Jan 2012 at 10:30am |
I tried that this morning. The tag is rather black with junk on it. I tried wiping it with a Q tip and some spray cleaner, but unsuccessful so far. I could try again tonight.
wjohn
Posted: 16 Jan 2012 at 10:31am |
The tag is the only method I know of - but that's not saying much, because I haven't been working on these carbs my whole life. Clean off the tag well and try Texas B's suggestion.
Texas B
Posted: 16 Jan 2012 at 10:37am |
Get something that eats paint - some of the good carb cleaner out of the bucket or paint remover or brake fluid - then steel wool wrapped around a small dowel. Gets you clean and a little shine on the high spots.
Texas B 39
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12018 |
Posted: 16 Jan 2012 at 5:57pm |
The B & C model Tractors shared the same carbs in most cases. Here's a few popular Zenith numbers that came on those particular model Tractors.
212845,212845-2,216937,224641,212844,212844-2, I've rebuilt most of em' and have the rebuild kits in stock for most AC applications. HTH Steve@B&B |
