B Front Hub Felt Seals
JIminArkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JIminArkansas Quote  Post ReplyReply Direct Link To This Post Topic: B Front Hub Felt Seals
    Posted: 12 Jan 2012 at 7:04pm
Any tips on installing would help. Felt is too tight in hub and wants to rotate with hub. Thanks in advance for any tips or tricks.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 8:29pm
soak the seals in the lightest oil you have. Our airplane seals we kept in a bag of 10-10 oil till we needed them. i did this on my C and it worked fine.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 8:52pm
I had the same issue, and after soaking them I was concerned about them drying out and then turning on the spindle. I took a very small amount of JB weld and put it on the metal edge of the seal and to the spindle. You have to clean both surfaces very well to make them grease free, and again, use a very small amount of the JB weld.  I applied with a toothpick to control the amount applied. It worked for me.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 9:43pm
I just buy rubber oil seals and install. Seems like they were standard size.
