D15 diesel compared to D15 gas
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: D15 diesel compared to D15 gas
    Posted: 09 Jan 2012 at 6:15pm
The rear end in a D15 diesel does it have the same drive ratio as a gas D15 series I or II.
Has anyone taken a diesel engine out of a series I D15 and installed it in a D15 series II gas . Were would you split the diesel engine?
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 6:24pm
I bought a D-15 D series I with a bad transmission in your country a few years ago. Bolted in a good D-14 trans and rear end. Second gear had different part numbers but the D-14 was up dated to the D-15 number in the book. The input shaft into the clutch will likely be different in the diesel. It is for a D-17 gas/diesel. We married the two just ahead of the transmission.
