allis G Almost finished
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: allis G Almost finished
    Posted: 07 Jan 2012 at 10:12pm
Starting working on the main tractor last week.
Lined the Gas tank with POR 15 and painted the fenders and gas tank three weeks ago.
Clean up the tractor with Oven cleaner and power wash when as about 45 degrees last week a little cold.
Started to clean up the brakes completely stop with dirt and grease.
Relining the brakes,
The left side final needed a bearing in the outer axle this tactor has been narrowed up
had to cut the weld off the shaft so i could get the bearing off thank goodness for the a grinder and torch and press to get these apart.
Edited by Richardmo - 30 Jan 2012 at 7:21pm
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 10:35pm
looking good, can't wait to come down and see all them tractors~!!
Justin Widlund (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Widlund (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 10:03am
Looks like you are coming along well.  Just a bit of advise (and perhaps you already know this) but be careful how and where you drive this rig as they can tip over fairly easily.  They are really unique though and you will have a great piece when it is completed.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 10:54am
Wonder how many years it took to build up that much "stuff" in the brakes?
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 11:49am
What's the purpose of the box above the hood?  Was this tractor used in a vinyard or do you know why it was norrowed down/
Dick
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 12:05pm
Dick
Battery!!!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 1:59pm
I've never seen one like that, must boil the water out of the battery fast
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 7:50pm
A little bit of dirt in the brakes? Holy Moly! Welcome to Daytona. Man, somebody put the "squeeze" on that little bugger! Looks like it was put in a giant vise.... LOL!
Steve@B&B
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 11:53pm
I have one of these just picked it up.  Do you know why it is so narrow?  Bruce
lbr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lbr Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 5:30am
We have 2 G's that are narrowed up. They were used around here (Indiana) to drill wheat in between the corn rows. My father did this with a new G in the 50"s. With the axles cut down they were able to drive down between 2 wide (38-40") rows of corn with a one  row wheat drill.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 10:28am
lbr & others; I met a guy at LaGrange, IN GOO (mid 90's ?) who formerly was an AC dealer in swOhio. He and a couple other dealers in tha area had a machinist-welder (guy or shop) modify a couple dozen G's as you describe. Wish I had made note of his name. We had two of those drills stored upstairs in grainery; unfortunately, they were scrapped years ago when Dad retired.  Herb
Bill Long View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 3:09pm
Just goes to show how versatile the G is. We widened them in our area but the strain on the axles caused problems. Never heard og narrowing them.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:49pm
not for sure why they were made i know some of tractor from Ca. were narrowed for vineyard work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2012 at 12:02am
update on the G last week painted the body of the tractor.
Last night i finished with most of the small items.
started putting the tractor back togther tonight still need to finish the front rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 8:42pm
almost complete need a battery top.
order my G decals from Wacker today.
need to put the front cultivators back on.
got the generator and lights working ordered a 6 volt battery today.
Here what ended up having in the tractor by the time i finish.
tractor run good and a quite transmission. had older but still good tires.
Allis G        $1750.00 including hauling from FL.
Gas tank lined POR 15                                                  $70.00
paint Valu pro PPG this includes primer.                        $250.00
2 new front tubes                                                       $28.00
Packing for both Clyinders                                           $50.00
Gear shift lever boot                                                   $11.00
seals inner outer axle                                                  $48.00
outer bearing                                                             $43.00
Misc bolts,light bulbs and gaskets material.                   $15.00
Decals        $33.00
3 bags of Coal sl*g                                                     $42.00
Oven cleaner and Brake cleaner                                    $52.00
New brake lining and ribit tool that i get to use again.     $46.00 Ribit tool $30.00
Air cleaner Cap                                                           $20.00
Used hood i had                                                         $35.00
Oil trans and engine oil filter                                         $55.00
Hydraulic hoses could not find the receipt        Guess      $46.00
My time many late nights                                                Free
sure i miss something but this is close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 9:52pm
Lookin' good from here!  Came out pretty nice! That thing is a pisser the way its smashed  down. Looks like somethin' knocked it on its side and ran over it.....  LOL!
Steve@B&B
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 10:17pm
   Looking pretty good !
   I can only see 2 pictures from the post on the 24th ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 11:27pm
I learned something tonight if the picture has been deleted from your file manager it removes the picture off the site.
Also reworked some wheels to go on my UC high crop while i was working the G.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2012 at 9:45pm
    Looking to buy or do some trading for a hyd  "G".   Hard cultivating with a right side tore rotator cuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 4:55pm
Allen.
With my right shoulder joint scheduled for replacement  surgery I'm having the same problem cultivating.  That's why I have grandkids. They may be easier to find than good Gs with hydraulics!
Dick
This page was generated in 0.191 seconds.
