D17 Exhaust manifold
Mrbill69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrbill69 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Exhaust manifold
    Posted: 07 Jan 2012 at 8:19am
I have a 59 D17 that needs a new exhaust manifold. What's the best one to get and the best place to get it. It is all original, paint and all as I got it from the prpporiginal owner years ago. I've been looking at manifolds in various places but don't see one like mine. The ones I see are either the one for wd, wd45 and early D17 with 3/8 studs and the bolt on muffler, or the one for the later D17's like series IV with the screw in muffler and the 7/16 studs. Well mine happens to have 7/16 studs and the bolt on muffler. Can I use the one for the early tractors by boring out the stud holes in the manifold or do I have to go with the later one and buy a screw in muffler?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 8:40am
What you probably have is a late Series II, which I have one that is guaranteed to be original, it has a the smaller muffler and the screw in manifold.  This is what you should buy.  In all my research I think now days you will have to buy a threaded adapter, or many of them come with them.  It may be possible that the original small diameter muffler simply fits inside the threads, I have not gotten to that yet on mine.  The parts book doesn't show a threaded adapter, but makes reference to a pipe exhaust p/n 70234541 which I think is the adapter.  The new threaded manifold was used effective with tractor S/N 320001
Edited by Orange Blood - 07 Jan 2012 at 8:41am
Still in use:
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 9:14am
I sell the manifold you need that is made in the USA. call 1-815-865-5372  www.normsactractors.com
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 10:23am
We have the manifold also.  I'll be happy to help with the stud size problem too.  Our manifolds are also American Made.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrbill69 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 3:27pm
Ok, I took it apart today. It has the bolt on muffler with no threads in the manifold but it has the 7/16 studs. I don't know about the series 1 or 2 stuff, but the serial no is 25xxx and it has the full flow oiling system. I'm going to replace 4 of the studs but only one is really bad. Thank God or someone for the 7/16 studs as they all turned without twisting off. So am I understanding right that a manifold is available that uses the 7/16 studs and don't use the screw in muffler?
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 7:47pm
   we carry the manifold you need with studs also if needed  1-800-254-3116 usa made
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 9:28pm
I did this on my early d17. New made in the usa VINSON manifold for 17 IV or 170 allis, Threaded one. Use a 1 1/2 inch "BLACK" pipe hardware store. Cut it in half so the there is only threads on one end. clean up the cut so there is no Burr left. Use a CASE VAC stanly ca3 muffler it is the same dementions body as a wd45 or early 17 one and has a 1 15/16" inlet that slips over the threaded pipe. This muffler has a block off plate in it's middle. I used a hole saw and a couple of drill extensions to cut it out. The muffler still burned the paint off where it was at. Worked good for me.
