SC blades
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Topic: SC blades
    Posted: 04 Jan 2012 at 8:55am
I have an extension for my SC blade but it doesn't match my blade as far as wear.  I have a short blade that is too worn and one that is too new. Where can I get bolt on blades to try to match this up.  thx, Jim
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 9:02am
I think you're referring to where to get replacement cutting edges. Check with a heavy equipment dealer or your local county/township shop. Often they have have odd lengths they can't use but will fit your blade.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 12:05pm
Well, I'm trying to search for the post I made this spring about the same problem.  I found an almost direct replacement from Cat but I can't remember the part number.  I know the edge itself was only $60 plus new hardware.
That took some time 7T-1633H is the Cat number I used.  I have some side by side pictures of the old and new edge.  I still have my old one that I'd ell.  Good condition, just about 1/2" more wore than my extensions.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 12:29pm
Yes cutting edge is the words.  Thx, I'll see what I can find.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 3:31pm
Do you recall if they have replacement cutting edges for the extensions?  That's what I am in need of.  Tkx, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 4:40pm
Buy as much edge as needed and cut accordingly.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 5:21pm
 Exactly ............ last time i got one  from the county hwy dept ..... ..just had to drill holes different .. cost me a 12 pack ....
 we were both happy ...
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 10:33am
If you buy the cutting edge from Cat and cut it down to size for the extensions, do they have holes that match up or do you have to drill those?  It's my understanding that drilling through those cutting edges can be rather tough.  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 10:36am
I used the fire wrench on mine which is for use versus show.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 10:40am
Well, for the holes, carriage bolts are used, so you'd need to have it cut out accordingly for the bolt end to hold.  Just wondering how I'm going to accomplish this.  Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 4:01pm
The left side of the cutting edge would cut down for the right side extension and vice versa.  That give you the set of carriage bolt holes where they need to be.  A gas axe would work as well as a 4" angle grinder with a few cutoff disks.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 7:40pm
Finally got around to stopping by Cat to try to figure out what I will need for the extensions cutting edges.  Seems you can get the six foot cutting edge, 1/2" thick, six inch wide for $106.  If you cut 18" off each end, you will have three of the four holes match up side to side.  The holes are about 1/4" lower from the top than the original.  Is this what you guys trying this found out?  Are there any problems or should I be looking at something else?  Thanks, Dave
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2012 at 7:48pm
put a new 6 foot on and use the one that is to new--- or if you have 2 ext. buy a 9 foot blade and put it on clare across.
