Got a Question
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Got a Question
    Posted: 31 Dec 2011 at 3:41pm
Will a 190 3pt. hitch work on a D17 IV?  The 17 has a snap hitch and they want to change it to a 3pt.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 6:16pm
Steve,  I'm not sure about the 190 working on a D17 Series IV,but it will work on a D19. I do believe there is a difference,but I could check that for you tomorrow,if you want? I have a factory three point setup on a D19 and a snap coupler off a D17 Series IV that I could measure the rear lift housing and see if they would bolt up. I'll be in touch,Steve.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 6:57pm
Steve - won't bolt up as the rear housings are completely different.  There may be some parts on the lift arms/lift links on a 190 that are the same but that's about it.  170/175/180/185 3 point will bolt right up.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 7:07pm
Mike...that's exactly what I was thinking. If I remember correctly,I checked all of this out 4-5 years ago and it didn't work then either! LOL! You guys have a Happy New Year!!!  Rick
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 7:11pm
 have 190 3 pt. for sale  1-800-254-3116  wrong section  sorry
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 6:24am
Thanks Rick and Mike for the information. Thats what I told him and just wanted to be sure I was correct. I know my brother tried to put a 180 3pt on a D19 and the top part worked but the bottom part would not bolt up. Thanks again.   Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 8:11am
I've never done this, but always thought there was a possible way to make the wider (D19-190) hitch work on a narrow (D17-170-180) rearend housing. I believe you could manufacture two spacer plates one inch thick to mount to the rearend and then have a second set of holes to line up with the hitch itself. It would require some threaded holes in this plate and some countersunk holes for others. Only downside I can see is the hitch would be located one inch further rearwards from where it normally is, which wouldn't bother anything. Something to maybe consider ??
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2012 at 8:18am
As Posted:
Got a Question
You too!!!
My whole life is one big question.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
