D14 Charging System |
AC Man
Topic: D14 Charging SystemPosted: 30 Dec 2011 at 6:59am |
Have burnt up four voltage regulators on my tractor. New wiring, double checked everything, tried two generators two amp gauges. Wired just like my I600 which is wired like D15 Series II. At wits end any ideas appreciated. Thanks
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 30 Dec 2011 at 10:53am |
Have you flashed the generator after wiring and before starting the engine? A generator building with the wrong polarity can be hard on the voltage regulator as in burning it up.
Are you SURE the wiring for the D14 should be the same as the D15 and I600? Gerald J. |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24883 |
Posted: 30 Dec 2011 at 1:44pm |
The I&T manual shows both D-14 and D-15 have same wiring,though D-14 is 6 volt. Page 88, figs 184, 185. That's for a series1 D-15.
Both use a 4 terminal regulator, series 2 D-15 uses a 3 terminal regulator.
hth jay
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 30 Dec 2011 at 6:56pm |
Better check your Battery! Sounds like the Battery could be the culprit....
Steve@B&B |
AC Man
Posted: 31 Dec 2011 at 6:36pm |
The shop that checked out generator suggested battery. I put new battery in ran additional ground wire directly from regulator to battery. Amp gauge shows 8 or 10 amps for about a minute then starts jumping from 0 to 8 or 10 then quits, regulator burn't up. One of the coils not whole regulator. About to give up wire in a cutout with resistor and switch.
