AA 9815: Good or bad?
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Topic: AA 9815: Good or bad?
    Posted: 29 Dec 2011 at 1:21pm
Does any body out there own one? Any pros or cons. Thinking about buying one and would like to know something about one. Is the front end heavy enough to put duals on? Any opinions would be appreciated. thanks   Frankmi
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 11:12am
It has the same drivetrain as a White 6215, with a different engine. The 9815 has a 6cyl 530ci 40 series Detroit, and the White has a 6cyl 505ci Cummins. I have spent many hours in a 6215. They both have a 18X9 powershift. The only complaint I have about the trans is between 9th and 10th gear is shifts the 2 speed and will stop (with implement in ground) and take off again. In the other gears it shifts smooth without stopping. It wouldnt be much of a problem but 9th and 10th gears are right in the middle of your field working speeds.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 1:48pm
Doesnt it do that because it goes into another range?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 4:21pm
Those transmissions can be calibrated to pretty much overcome that problem. Don't know if that information is in the owners manual or not. It involves programming your trans controller to "CAL" and running over a large block of wood with one rear wheel. The controller goes thru a "count-down" procedure until the clutches are tight enough to run over the block. Fine tuning can be done from there. I would expect to have to do this every 1,000 hrs or so?
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2011 at 6:04pm
The 9815 is indeed a big horse.  We have a customer that has one and if memory serves me it is pushing out 250+ hp.  We did have to overhaul the engine shortly after he bought it but I think the engine had been dusted due to a leak on the intake system somewhere.  He wanted to put front duals on it when he purchased it, we talked to AGCO and they said the front end was not heavy enough for duals but he put them on anyway and that machine has ran for over five years without a problem.  He has used it on his DMI Tigermate for a few years and now has a 12 Krause Dominator and it handles it well.
Jim
