6080 HELP
farminharmon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Topic: 6080 HELP
    Posted: 29 Dec 2011 at 11:03am
I have an Allis Chalmers 6080 that my mechanic says the nut has come off the pinion in the rear end.  Anybody experienced this?  If so I need advice as to what to do where to get parts?  What kinda repair costs might I expect and what kind of a job is it to fix this?  Any other recommendations would be helpful? Thanks.
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 5:02pm
If your really, really, really lucky, you stopped it when you heard/felt it. I have took the top plate off and restarted and tightened the nut, but I have seen them where they run it for a long time wondering what it was and had to pull the whole rear end apart(separate from trans, pull final drives, pull ring and pinion) and replace the shaft and bearings. Not cheap,.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 6:19pm
Any idea on cost? My mechanic said that he would also have to pull the engine. Is this true?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2011 at 9:44pm
No, you don't have to pull the engine.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 3:16pm
Bump.
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2012 at 5:02pm
I have all the parts you will need to fix it. I am not sure why he would need to take the engine out to fix the rearend.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 8:31am
Brian, what parts am I probably looking at needing and any idea on the cost.
