AC D17 IDENTIFICATION ?
ESV2K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ESV2K Quote  Post ReplyReply Direct Link To This Post Topic: AC D17 IDENTIFICATION ?
    Posted: 28 Dec 2011 at 9:26am
I am trying to fix a D17 for my son, but I can't locate the ID plate to determine what parts to buy. Where in the world did they place it? HA!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 9:29am
The serial number is on the left side on the torque tube just behind where the engine bolts in. If the tractor has been painted, you will likely have to scrape the paint off. There is no id plate. The numbers are stamped into the casting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ESV2K Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 9:39am
I really appreciate the help----I have already spent several hours searching. I'll go out there and loos ASAP! HA! Thanks.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 9:42am
Also, once you find the serial number you can check the date with the listing on another page of this site so you will know the year of the unit.
There are some features of every tractor that can help identify the year but the serial number is best.
Parts supply is available through sponsor's of this site.
Let us know how it goes.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote ESV2K Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:15am
Ok, I found the ID Number exactly where you said it would be. The numbers stamped into the casting is" D17   32212
I looked in the Serial Number reference list but can't find this number. I was told that this tractor was made in the 60's.
Ed
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:22am
Built in 1960, almost 1961.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:23am
 Terry Deans data book indicates your tractor is from 1960.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ESV2K Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:27am
Thanks guys. Also, I see items on ebay for this tractor listed as being for series I or II all the way up to a series 5. How can I determine if this applys to this tractor?
Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:33am
There wasn't a series 5, just up to Series 4.
Not hardly any difference between 1 & 2. 3 & 4 had an oval muffler and a few other goodies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ESV2K Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:36am
Hi Bill, ok---this one has the Oval Muffler on it---they actually cut the hood to fit that muffler in there---HA!
Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:42am
The serial number reference page gives the range of numbers for a given year. Your's fell toward the end of 1960 as the 1961 numbers started shortly right after your number.
You probably have a Series 1, but I don't know where the break is where Series 2 started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ESV2K Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 10:52am
Ok. Thanks for all the help Bill---it was Most Appreciated.
Ed
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 11:11am
Series II tractors began with #32001, so you have a Series II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ESV2K Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2011 at 11:28am
Thanks Bill----that was the last remaining piece of the puzzle for this tractor. Now all I have to do is get the problem fixed----HA.
Ed
