d 15 gear jumper |
Post Reply ![]() |
cobra ![]() Silver Level ![]() ![]() Joined: 16 Oct 2011 Location: p.e.i. canada Points: 66 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Dec 2011 at 5:49am |
every now and then my d15 series II gas engine will pop out of a forward gear.I think it is mostly second gear but am not sure as i have not used it a great deal. thankfully no snow yet but it will come. thanks
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
Thats a common issue for these collar shift trans. There are some"fixes" you can try like making sure fork isn't bent or maybe moving detent grove on shift rail . Likely a real fix will involve replacement of worn parts (complete disassembly) and a thick checkbook !!
ive seen a guy use a bungie cord to hold his tractor in gear.is this acceptable and when u say expensive to fix is it mostly parts or time or both as well as difficult. thanks
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
thanks herb. ill try this happy new year
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Every time that pops out of gear, it does more damage to the splines. It is possible the gear splines are OK if the collar was replaced now. Proper engagement is also helpful in saving the splines.
Post Reply ![]() |
