Hay Mowers
farmboycitygirl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboycitygirl Quote  Post ReplyReply Direct Link To This Post Topic: Hay Mowers
    Posted: 19 Dec 2011 at 10:24am
Hey guys need some help.  My son is going to start mowing hay with me this next year.  He has been raking for the last couple of years.  I want to start him on a sickle mower/cond and don't want something real expensive since he has never mowed before (you never know with 9+ foot hanging out to the side of the tractor).  I seen a couple of not so good post (on this site) on a new holland 489 so I thought I would ask would you all what you use and recommend.
Thanks in advance for the help.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 12:54pm
Just make sure the wobble box is tight. It's about a $1000 for a reman one and they aren't that fun to change. I've been noticing a different series of older NH binds that have a simple offset over bearings for a wobble mechanisem out in the open easy to service that I am going to look into if I go bigger than my 474. By the way the 489 I got for parts takes up the whole road if that matters to you. Some people had good luck with that syle just check yours over better than I did mine.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 2:31pm
We've got an old 479, works pretty good considering its basically worn out.
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 6:16pm
I have a NH 477 , I can run nicely with the wd and in thicker hay I have to run slow. But 100 Bales acre I run in 3rd. , and that is on some steeper hills too. In thick wet hay she will pack full and that is a pain, but I'm talking 140-150 bales to acre or 2.75 tons to acre. Nice size to move down the road. You can still get parts for it.
Edited by Teddy (punchie) - 19 Dec 2011 at 6:17pm
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:39pm
We've been running a 488 for about 10 years with no big problems, check out the wobble box good, and keep it greased. They are a bit wide for road transport.
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 9:09pm
After buying a Hesston 1060 discbine, I can't figure out why anyone ever made a sickle mower. I can mow alfalfa as fast as the 190XT will go and it never plugs up and it cuts really clean. I have a JD sickle MOCO sitting here but don't intend to ever use it again.
Dannyhtn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dannyhtn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 11:38pm
I know sickle mowers and disc mowers but what is a discbine
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 5:31pm
It is a trailing type disc mower with conditioning rollers or flails in it.
1969 190XT series 3
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 7:41pm
I agree with Dave on the discbine. Having said that I have a 488 NH that is a good machine in average (not thick) hay. Can cut 6 mph in alfalfa with it. Go 8 with a GEHL discbine.
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 7:50pm
I run a 499 NH and have had good luck with it, doesnt like wet pocket gopher mounds though
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 7:59pm
Not sure about prices where you guys are. A disc mower around here start at 3500 and go up from there, average around 5000.   For me to go a little faster and do just a bit better of a job not worth it, most of the fields I do you would be getting into trouble going 6 MPH.  In time I may get one for second cutting, but for now I'll use the 1000-1500 haybine.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 8:32pm
Likewise I want and need a discbine. But for now I ave a 489 and all income goes into pocket not paying for new to me equipment. lol But I want a discbine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 11:22pm
I bought my Hesston discbine at an auction for $2300. Best buy I have made. I hated constantly unplugging that JD MOCO. With the JD, I mowed at about 4 MPH. With the discbine, I mow at about 10 MPH. Less than half the time actually mowing.
Edited by DaveCinIN - 20 Dec 2011 at 11:31pm
