G engine removal, trying anyway !
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Topic: G engine removal, trying anyway !
    Posted: 18 Dec 2011 at 1:26pm
Well, with the sun shining nice I figured I'd spend the afternoon getting this G engine removed. Thing is, it has other ideas ! Barely broke the paint around bell housing and engine and that's as much as it will move. If the crank was worked on before, it's been a while and the little girl just don't want to come apart again.
Here's a couple shots of what I rigged up to lift it with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 5:43pm
Been trying to post these for hours, maybe only a couple at a time.
It finally gave up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 5:46pm
Ok, that worked
Never mounted an engine to a stand before, glad no one was here to video it !
Clutch doesn't look to bad but I may replace it since it's out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 5:50pm
And finally, it's sitting in my living room !
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 5:55pm
Small pieces can go to kitchen table
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 9:25pm
where you guna put the parts washer and air compresser.   what did the lady of the house say? did she help you get it in ?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 12:21am
oh man!!! there's lots of things....my ole lady....oooops...i mean my loving wife...lets me do...but i DON'T think that would be one of them!!!   the living room???   whew!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 3:31am
Well guys, there is no lady of the house so I don't have to worry about that ! Parts washing will have to be taken outside but the air compressor is in the garage, plenty of hose to reach. Doubt if I need it now, had to use the air impact to get the flywheel off. The B&D 18volt impact brought the pressure plate bolts off easy enough. It'll likely do most anything else needed. Still got to pull the carb off, it still has gas in it and needs cleaned anyway, then I can turn the whole thing over and get start.
Redpower1456 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redpower1456 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 5:02am
uh-h-hhhhh...... OK..... Good thing that's not a D-21 you're working on in your living room and on your front porch......
"Git 'r done!" Or how does that NIKE ad go- "Just Do It!"
Good luck with your project.
Edited by Redpower1456 - 19 Dec 2011 at 5:12am
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 10:02am
I never knew how packed a G motor is.;) That is a lot of parts on that small of a motor.lol Good luck with it.
Edited by Josh Day - 19 Dec 2011 at 10:02am
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 10:57am
Didn'y you just get that tractor back together not that long ago?
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 12:05pm
I didn't do anything inside the engine then, Jeff.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:10pm
Sorry it gave you so much grief.  When I had to take mine out I just looped a chain between 2 head studs and strong armed it off the back!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:23pm
The guide pin, or whatever you call it, on the starter side was the culprit for all the trouble. It was seriously stuck ! Took a good bit of wiggling and penetrating oil to get it to come loose. Yeah, I'm sore but I was nearly lifting the back tires off the porch !
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 8:33pm
You're my hero!
Ha!
Best regards,
Scott
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 9:57pm
Hello Warren   Did a clutch job last week BIG pry bar that dowel pin was tight.   Why are you pulling the engine???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 3:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 6:42am
I'd have thought it might have been a bit easier if you'ld taken the rear implement bars off to get a straighter pull..but your living room 'shop' reminds me of my old 3 bedroom apartment where one room was my 'shop'(motorcycle WAS in the living room though).I rebuilt my 58 willys 4wd pickup in there(trannies,electrical) any parts that fit a shopping cart came up and were made new.Ah..memories..only thing left of the Willys...sigh...
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 8:47am
I helped my friend rebuild a VW motor in his kitchen yrs ago ,it was kind of nice the tv was on and the fridge had plenty of beer but the table was never the same after and his landlord was not a happy camper .But I did put that as one thing not to do in my leases for my rentals lol
SenseiCrusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SenseiCrusher Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 9:44am
I rebuilt my old 1967 shovel head Harley in my college dorm room. The RA was pissed when I dumped some used oil into the toilet. He really blew a gasket when I finished butchering a deer in the showers later that semester. But doing that in the house? You are my hero!!
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 11:56am
Warren:  Since you don't have a wife to complain the dishwasher on "pots and pans" does a great job of cleaning parts!!
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 12:08pm
You might be a genuine allis tractor nut IF..........lol
Fill in the rest with Jeff Foxworthys voiceover.
Galatians 5:22-24
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 1:11pm
Don't have a fire anywhere in the house anytime in the near future. The residue of oil and gasoline vapors will trigger the arson investigation charging you with arson. Even if the fire is a far part of the house, they will detect the petroleum in a place its not normally.
Gerald J.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 5:41pm
As long as that engine doesn't end up in the bed with you, you have my vote as one dedicated AC follower, great post, hope all goes well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 6:30pm
In bed with me, Chris ?!?! NO WORRY !
That would be bad, Gerald, so no fires ! I've got two more to do ! Hope they don't require much internal work.
Don, I've been waiting for,"You might be a redneck if you rebuild engines in your livingroom!"...
Rawleigh, my dishwashers are fastened to the end of my arms, so, yeah, they do a good job !
As for me being a hero, you guys may need to set your standards a bit higher ! haha
