PLOW CUTTER ?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: PLOW CUTTER ?
    Posted: 17 Dec 2011 at 2:01pm
ON a plow That has the rolling cutters with a bushing in the hub what would work for a new bushing? mine is on a 2000 series plow it has a 5/8 hole for the bolt can you still get these from AGCO ? or is there some kind of pipe you can make one out of? it is hard to find pipe with an ID if 5/8 in.Thanks for any ideals TOM.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 3:05pm
Steel selling shops have bushing stock that is a hair undersize on the inside and a hair oversize on the outside so it can be turned to the exact size.
Those coulter bushings are probably in the plow bottoms and coulters book at
http://www.grandpastractor.com/phpBB3/index.php. Look at the coulter on page 27, its the only one in my printed copy of that book that has a 5/8" bolt. The bushing or bearing is 344227. I have no idea if AGCO still has any. It is like the coulter on my 2000 plow.
According to one handbook, 1/2" pipe is .003" under 5/8" ID. WIth there often being a weld seam it would take running a 5/8" drill through to get it up to clearance on a 5/8" bolt (axle). Or with a metal lathe its not beyond reason to start with a solid rod and bore it out.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 7:46pm
Tom , probably can buy an 841 bronze, Oil-Lite bushing from McMaster Carr. Probably can buy exact size you need. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:20pm
THANKS TRACY
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 10:06pm
My book is showing a bearing and bearing cup for the 2000 coulter. A very common tube type bearing seems to be a 317992. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 11:22pm
Yes 317992 is in my book many times, but it won't fit a 5/8" bolt when its made for a 1/2" bolt that accompanies it in all those pages.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 8:47am
McMaster Carr has ASAE 660 (932 alloy) bronze which would do just fine as long as you grease it once in awhile.
For Shaft Dia.: 5/8"
3/4"1/2"6381K1411.83
3/4"5/8"6381K535.13
3/4"3/4"6381K5312.03
3/4"7/8"6381K5325.85
3/4"1"6381K5332.46
3/4"1 1/8"6381K5342.42
3/4"1 1/4"6381K5352.85
3/4"1 1/2"6381K5363.11
3/4"3"6381K610.02
13/16"1/2"6381K5375.50
13/16"3/4"6381K5386.01
13/16"1"6381K5393.32
13/16"3"6381K710.50
7/8"5/8"6381K545.94
7/8"3/4"6381K5412.98
7/8"1"6381K5423.50
7/8"1 1/2"6381K5436.04
7/8"1 3/4"6381K5445.74
7/8"3"6381K810.94
1"3/4"6381K5456.97
1"2"6381K1516.21
1"3"6381K911.90
1 1/8"1 1/2"6381K1616.73
Here is the page.
http://www.mcmaster.com/#sae-660-bronze-bushings/=fezxhn
You should be able to pick something up at your local bearing supply store.
Edited by CTuckerNWIL - 18 Dec 2011 at 8:48am
This page was generated in 0.150 seconds.
