AC D14 Starter
dishinhof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dishinhof Quote  Post ReplyReply Direct Link To This Post Topic: AC D14 Starter
    Posted: 16 Dec 2011 at 8:05pm
My starter just spins without making contact. When i had the starter out, it looked liked it was not extending all the way. Is this common problem?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 8:25pm
SOUNDS LIKE A BROKEN SPRING IN THE STARTER DRIVE.
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 8:27pm
Not necessarily a common problem but it happens with starters of all makes.  Does the starter motor seem to be turning up to full speed?   If yes then the problem is probably in the starter drive.   Might be time for a trip to the startern/generator shop.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 9:51pm
The Bendix may just be stuck. Had that happen on my D14. Just pull the motor and check it. Bob
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 11:05pm
I vote for the spring on the starter...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dishinhof Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 12:31am
Thanks. i thought i might have to replace the drive. I'll let you know what happens after i replace it.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2011 at 8:32am
Is your battery a 6 volt  or  12 volt?
Gary
This page was generated in 0.095 seconds.
