Unbelievable!
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Unbelievable!
    Posted: 15 Dec 2011 at 11:58pm
ALLIS EXPRESS!
This year:
Cen IA John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cen IA John Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 12:04am
Well I need my 180 pump overhauled and they want $1800 for the kit, no labor here in Iowa. $1900 for a brand new isn't out of line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 12:13am
I've got one that looks like new on my 185 parts tractor I would sell.....make me an offer I can't refuse....
ALLIS EXPRESS!
This year:
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 2:57am
It's priced right.
Can't wait to see the repiles on this one.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 10:29am
guess it just depends on if you really have to have a "new" one. I got a rebuilt hyp pump for my 200 from Cook tractor for $825 there is a $125 core charge. So... for $700 i have one that works like new. Maybe this helps.
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 10:40am
thats why ive collected hydraulic valves, pumps, hoses, drive motors exc!
andrew
2 WDs
B
B112
D14
D15 shuttle
180
185
7040
Hd7w
D14
D15
185
7040 pd
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 12:31pm
its priced right, if it was truley rebuilt it would cost way more than 825.00 the seal kits alone are 75.00 apeace and you need three of them, not to mention the brass wear plates and gears if needed plus bearings , my guess is the one overhauled was just seal kits at 210.00 dollars plus labor. just my 2 cents. there are a lot of different so called overhauls, some are just outside cleaning and the real ones are expensive,
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 2:56pm
Good point. See how long this one lasts. Still better than the one i took off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 2:57pm
As long as it's pumping that's a good thing!!!
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 8:10pm
A lot of times You can just replace the wear plates to get the pump back to spec. If you need gears and bearings it can get expensive fast.
I think I recall seeing somebody offer a new pump for less than that though. I think it was less than a grand. It was a new aftermarket pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 8:36pm
Seems everything I 'collect' nobody wants to buy for a reasonable amount let alone what it's worth...sigh....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 8:41pm
You may want to consider replacing plates and backup seals in your "working good" pump.The one on my 220 had been run "leaking by" long enough to erode the housing behind the wear plate to where the new "squiggly" backup seal had no support in one small spot.The old seal was blown out in that spot.Took a new pump to fix it. Had it been resealed in time,the erosion likely would have been prevented.
Mike_426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike_426 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 9:27pm
I just had a pump for my 200 delivered from Cook tractor in MO $700.00 one year warranty $150.00 core. Works and looks perfect!
G, 200, 8050 mfd, D17, 195 chainsaw, c-wide front
