Snap in WD45 Hand Clutch
GlenB(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Snap in WD45 Hand Clutch
    Posted: 15 Dec 2011 at 10:54pm
I have the top cover off of my WD45 hand clutch.  I have egaged and released the hand clutch and watched the parts moving.  This tractor just does not have the "snap" that other WD45s do when you disengage the hand clutch.  What does it take to get one to "snap" again?  There seems to be plenty of clutch lining.  Thank you for your advice!
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 10:59pm
Its been a little bit since I adjusted one..but it sounds like you need to remove some shims (equally) from each pressure plate bolt (there are 3 if im not mistaken) under that cover.  Take one bolt out at a time and remove the same thickness shim from each bolt.  start with the thinnest first and see what that gets ya.  -Wes
This page was generated in 0.049 seconds.
