D17 Series 4 Hydrolic lift arms
dishtech43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dishtech43 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 4 Hydrolic lift arms
    Posted: 12 Dec 2011 at 10:26am
I have a D17 Series 4,that I found in the woods,been sitting for about 18 years..Getting ready to put loader on it .But the problem is.after i got it running,I raised the 3 point lift arms,and they wont go back down! IS there a valve stuck,or what.I did replace all hydraulic fluids.Dont have a book on this tractor.just dont know where to start.andy ideals guys.Thanks alot.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 11:00am
Linkage is most likely stuck on draft control from sitting. Remove all the small linkage from under tractor going to rear lift and free it all up. Likely has the draft stuck in raise position.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 9:55pm
It is the traction booster linkage that is rusted in the activated position.  Since the tractor has been sitting in the woods for 18 years, I would take the mechanical linkage apart and clean and lubricate all of the pivot points.  The valve body itself should be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2011 at 10:10pm
Cylinders are rusted on inside. Take a hyd. hose off one cylinder and see if it will go down.  If it was linkage, it would have went up as soon as it started.
  Put alot of weight on it. May have to take cylinders apart and hone.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote dishtech43 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2012 at 7:11pm
got it.I bled the lines,and seems to work ok..kinda slow.but working with enough weight on them.thanks  Guys..
