AC Hay Conditioner |
bigbird
Joined: 22 Sep 2009 Location: Franklin, IN Points: 77 |
Topic: AC Hay ConditionerPosted: 11 Dec 2011 at 8:19pm |
Does anybody have any information on a hay conditioner, we called them crimpers. My son found one in some weeds at a neighbors who was giving him the scrap for cleaning it up. It clearly has an Allis-Chalmers decal on it, but cannot find the model or any ID plate. I thought it best to scrap, but he loves anything Allis. So we took it home, put ne tires and a new chain, with about a can of penetrating oil, filled the gearbox. Lo and behopld hooked it up and ran great. It has a smooth rubber roll, and a notched steel one. A post on ebay lists a model 25, but we just don't know. Who knows a little paint and we might have something. Any ideas? I can't find anything in the Agco on-line books, and dealer doesn't have anything. Thanks
Rfdeere
Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
Posted: 11 Dec 2011 at 8:45pm |
AC made a hay conditioner from 1960 to 1970. Your description describes this machine. It had 6 foot long rolls. It did not have a model number from what I have read.
http://www.rumelyallis.com |
ctbowles58
Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
Posted: 11 Dec 2011 at 9:08pm |
thay made a 904 one of the later models
Rfdeere
Posted: 11 Dec 2011 at 9:42pm |
The 904 is a mower-conditioner.
Bill(MO)
Posted: 12 Dec 2011 at 12:51am |
I have an original operator/parts manual and there is no model number shown. The only option was a hyd. lift att. It also shows an improvement pkg shipped to dealers for models up to 1101.
Should be a serial no. stamped on R.H. side plate. Bill(MO) |
Armand(AZ)
Posted: 12 Dec 2011 at 6:36am |
The hay conditioner didn't have a model number to my knowledge. I built a model of one and have the manual. You can see the model on my website for comparison: acmodelsofarizona.weebly.com
Armand
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1046 |
Posted: 12 Dec 2011 at 7:08am |
I,ve pulled one over many,many acres with Farmall H tractor. They are OK in short hay,but in tall orchard grass or fescue it will constantly wrap the steel roller. You will need a SHARP knife and tons of patience. I know it is AC,but in my opinion they aren't worth TWO DEAD FLIES. This is one machine that would even make the pope cuss.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5474 |
Posted: 26 Dec 2019 at 9:41am |
Found this old post and actually went to look at one the other day. Unfortunately it has a bent pto shaft. Does anyone have a measurement for a pto shaft? Not sure if Tractor supply has one the correct length?
michiganmarty
Joined: 19 Feb 2012 Location: central mi Points: 69 |
Posted: 27 Dec 2019 at 8:18pm |
we ran one, and yes it tried your patience at time, if the divider board work on the mower, it worked ok, but if it wasnt didided clean it would plug on the end, and would need to be cut out. i think the roll was worn, and that why it did that. it worked better the newer it was. Did help dry the hay though, maybe a day or day and 1/2. earlier.
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Posted: 27 Dec 2019 at 8:50pm |
I still use one! I’ve never had it wrap up yet and hope that it doesn’t. It does work well.
Thanks & God Bless
Dennis |
AC720Man
Posted: 27 Dec 2019 at 9:21pm |
Dennis, can you get me a length on the pto shaft on yours? I have seen your video and it appears to work well.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12421 |
Posted: 28 Dec 2019 at 7:45am |
That’s got to be one of the most amazing posts I’ve ever seen! Never? Wow! We used one way back in the way back days. Also had a New Idea. They both plugged plenty! |
Mikez
Posted: 28 Dec 2019 at 9:49am |
Wow that is something. We always thought it was certain types of hay that wrapped or not. Some fields didn't give us trouble an some did every time. I had an axe laying right on conditioner and when it wrapped would cut through the wad then take it to the nearest woodchuck mound or any other mound and drive over it, that would turn the bottom roll an turn the plugged hay out.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 28 Dec 2019 at 4:36pm |
Checking with Pop's 1960 Price Book there is a hay conditioner listed. PTO Driven Includes 72" Upper rubber covered roll, 72" lower staggered bars on solid steel tube, hand lever control, two 13" discs and rims - less tires, slip clutch Enclosed Gear Box and Roller Chain Drives Hay Conditioner - less tires $ 740.00 5.90 - 15" Tires - rib implement $ 50.00 Hydraulic Lift Attachment - $ 16.00 Good Luck! Bill Long Hey Armand, Is there anything Allis Chalmers that you DO NOT have a model of - including Pop's Dealership O. E. Long & Son
Edited by Bill Long - 28 Dec 2019 at 4:38pm |
Mikez
Posted: 28 Dec 2019 at 8:05pm |
Hey bill here's a picture of a purchase statement from my grandfathers dealership. It's heading is. Allis-Chalmers manufacturing company. Syracuse, New York
![]() In the middle is hay conditioner Oh here on the second page he got two in 63 ![]() I'll have to look SR number of the one at the farm, one of these went to they're farm an still have in barn Edited by Mikez - 28 Dec 2019 at 8:22pm |
AC720Man
Posted: 29 Dec 2019 at 5:50pm |
That’s cool Mike. Great to have the paperwork.
DennisA (IL)
Posted: 01 Jan 2020 at 9:05pm |
Here is the measurement 52.5". That is with the P.T.O. pulled out about 10" as I could not get it slid all the way in. |
Thanks & God Bless
Dennis |
Steve Bright
Joined: 14 Sep 2009 Location: Martinsville, I Points: 2107 |
Posted: 02 Jan 2020 at 8:03am |
My Dad bought 1 new in 1961, I pulled it over many acres, Dad mowed hay with a WD 45, I pulled the crimper with a D 14.
AC720Man
Posted: 02 Jan 2020 at 9:27am |
Thanks Dennis, I will see if I can find one at TSC.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55290 |
Posted: 02 Jan 2020 at 6:03pm |
They'll likely charge you $300 and a 3 week wait, from my experience
Try surpluscenter, at the link, below, they might have one, hard part, sometimes is matching to the machine's end shaft... ![]() Edited by DiyDave - 02 Jan 2020 at 6:08pm |
AC720Man
Posted: 02 Jan 2020 at 8:07pm |
Thanks, I will check them out
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 03 Jan 2020 at 7:21am |
Dad mowed with a side mount 80 or 82 and pulled an AC crimper directly behind his WD45 or WD except for the initial round. He mowed mostly straight alfalfa and it worked well but he has said it didn't like grass. Grass around here usually doesn't need crimping to dry fast.
Wink I am a Russian Bot |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 03 Jan 2020 at 9:13am |
https://www.sloanex.com/contact-us |
Lonn
Posted: 03 Jan 2020 at 9:34am |
When I worked at the local CaseIH dealer and before that the local AGCO dealer, we just built PTO shafts to customers needs. Had 10 foot long shafts of various sizes and cut to length, grabbed the correct yokes and cross bearing of the shelf and put it together by welding or pinned depending on what was needed or what worked. When I had a bent PTO shaft on my Duetz-Allis discbine I just removed old shaft from yoke went to the CaseIH dealer and they cut me off a chunk of metric shaft and I put it back together. Can't remember if it was held together with a roll pin or if I welded it together. Worked fine.
orangereborn
Posted: 03 Jan 2020 at 12:20pm |
Tbone95
Posted: 03 Jan 2020 at 1:21pm |
We could never get the simultaneous pull to work worth beans. Just wasn't lined up good enough, and made the plugging nightmare 3 x worse.
