snap couple plow ID
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: snap couple plow ID
    Posted: 09 Dec 2011 at 1:58pm
anyone tell me what this is.  All I know is it's a 2 bottom and was told it is a "high beam" plow.
Thanks
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:00pm
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:06pm
  It is a Model 82. They had alot more clearance for trash than the earlier versions, so you could describe it as a "High Beam".
http://www.rumelyallis.com
WilliamNEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WilliamNEOH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:12pm
I HAVE NO IDEA BUT I HAVE ONE THAT LOOKS LIKE IT USED TO BE A 3 BOTTOM, STILL HAS THE ARM TO ATTACH ANOTHER BOTTOM. ALL KNOW IT'S SOME TYPE OF RESET PLOW.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:15pm
   3 bottom would be a model 83.
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 2:38pm
 this model of plow will trip if you hit a rock or a tree root and when it trips you stop and back up and reset and go again instead of breaking one of the two bolts on the other style plows that has soft shear bolts that will break
a member of hendricks county antique tractor and machinery association club.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2011 at 4:11pm
That trip mechanism is for a 9000, not an 80 series unless very late. Like after January 1965. Then the parts book says for 60 and 80 series plows. The frame is closer to an 80 than a 9000 because my book doesn't show a 9000 smaller than 4 bottoms.
I repeat, the plow bottoms do NOT identify the plow frame. They were sold separately and have their own book. To identify the plow bottoms you will need to find a number on frog, moldboard, or share and in some families like 371, 372, and 373 only the moldboard is different to identify the plow bottom they share other parts like frog and share and then the same landsides can be fit to nearly all bottoms and nearly all bottoms can be fit to any plow frame.
The plow bottoms pictures are shown looking at the frog with the play laying on the landside.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 9:00am
Is there a ID mark on the plow its self that I can look for??  I know it has the small AC emblem you can see in the one picture up on the front of the plow and on the back frame is a "shiney" for lack of a better term decal that is listing patent numbers.  It reminds me of polished tin foil.  I think is measures out at a 16" bottom.  What are they worth??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2011 at 9:17am
I've not seen any but I've not looked at a bunch of unrestored plows. There is a chance of there being part numbers on any of the major parts, but not on hardware. And sometimes parts are unique to a particular plow frame and model. Without numbers on plow frame parts, either model or part numbers the only ID is by the criteria I've been using, comparing to the illustrations in the parts catalog.
Gerald J.
