Clutch Adj 175 Crophustler
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Topic: Clutch Adj 175 Crophustler
    Posted: 06 Dec 2011 at 11:34am
The clutch pedal goes to the bottom, any adjustment or is it clutch time? I don't know if it slips or difficult to get in gear, friend has it in shop to repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:07pm
Bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 8:28pm
Throwout brg sleeve may have rotated due to loose hardware on the fork. ...probably takes a split to fix this. Throwout brg failure and ate it's way thru the fingers....split to fix. The clutch pedal rod may have pushed thru the trunnion....a fine threaded nut on the rod will fix this easily...no splt.  If it has 3000 or more hrs on it it might need a clutch anyway.
Bret (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bret (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2011 at 6:56am
Had a Series IV couple of years ago with a low clutch pedal, didn't happen all at once but after a couple of days using the tractor the pedal became so low that couldn't get i in gear anymore.  Split the tractor and found the Clutch Lever had cracked.  When clutch pedal was depressed it wasn't moving the release bearing collar far enough to disengage the clutch.  Clutch Lever AGCO Part # 70242463 was still available from AGCO.  It takes a Qty. of 2 parts that get bolted together.
Heres a link to the AGCO parts book, scroll down to page 186 Drive Train, Controls, Clutch Pedal
