Gleaner E question
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E question
    Posted: 29 Nov 2011 at 7:39pm
Anybody know how to set the governer on a 226 gas eng in an E gleaner?
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 8:05pm
i don't remenber how to set governer, but when we worked on them at the dealership, the first thing we checked was the clyinder bars. If they are worn very much, it will make the governer VERY sluggish acting like it needs to be adjusted.  If the bars are worn you can either turn them or replace them.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 10:13pm
A spring controls the governed speed. You can pull the cover off the front of the governor and replace the spring if needed. The governor weights could be stuck also.
What's your problem? too many RPMs or not enough? Or is it just not reacting to load?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2011 at 10:25pm
If the gov. works slow, clean the thrittle shaft on carb. If the link on carb where the cable controles the carb. is rusty or dirty or cable not lined with link, it will bind causing poor gov. action.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 7:11pm
Just trying to help a friend, sat in a shed for 28 years, he started taking everything apart before knowing what he was doing. He said he adjusted the screw on the governer and took the carb off? don't know why. just wanted to set everything back right before trying to start it up.
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2011 at 7:27pm
Is there oil cap on the governor it the machine sat for 28 years perhaps the springs inside are seized and need lubrication
Farm stuff 8050,6690,175,F2,5050,WD
