ALLIS 190 AND WESTENDORF WL 27
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS 190 AND WESTENDORF WL 27
    Posted: 14 Nov 2011 at 5:12pm
hAS ANY BODY GOT EXPERIENCE AND OR PHOTOS WITH MOUNTING  THE WESTENDORF WL27 ON A 190 ?. i AM GOING TO DO IT AND WESTENDORF SAID THEY DON'T HAVE A KIT OR PLANS.  Okay iam not really doing it  but have a very competent welder assembler mechanic that will do it. tRACTORMAN
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 7:30pm
I'm pretty sure Westendorf did make brackets for a 190. Maybe they quit because of low demand. I know for a fact they make them for a 185. My uncle has a WL 27 on his 185. I would say a set of 185 brackets could be made to fit with minimal modifications.
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 8:15pm
Our Westendorf TA26 loader was off of a 190XT, we have it on our 185, everything was the same except for where it bolts to the rear axle, we had to make a spacer out of tubing and drop it down with some plate steel.  The last time I talked to them they could make the brackets for just about any model/any brand, but I'm not sure what it would cost.
Edited by StewartMD - 14 Nov 2011 at 8:16pm
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 8:32pm
but   but   this one is coming off a deere 3010, could it be a lot different ?   tractorman
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 8:50pm
we got a kelly 800 off a 1650 oliver for 150$ when i called kelly mfg they said they csnt sell me the brackets cause the loader was on an oliver???  figure that one out  we had a local steel shop make  everything we needed and it works fine
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2011 at 10:07pm
I was under the impression that you were wanting to buy the correct brackets but Westendorf didn't offer them.
If it's coming off a JD, there could be quite a bit of bracket modification.
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 6:26am
I would suggest getting a ballpark price from your welder, and getting a quote from Westendorf,  if it comes from Westendorf you will know it will be built heavy enough in the right places.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2011 at 6:36am
I, my Dad and a neighbor modified a CaseIH 2250 off a 3220 (way too little of a tractor for the loader) to fit my D19. Works good. Well, as good as a D19 would ever work with the standard hydraulics. Took one weekend with a lot of BS sessions and some beer.
Wink
I am a Russian Bot
