Steel wheels for a UC
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: Steel wheels for a UC
    Posted: 04 Nov 2011 at 4:31pm
Does anyone have a set of steel wheels for a UC laying around? I'd like to get the rubber off mine.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 6:11pm
Do the older skelton steel wheels for UC's, still exist?
I have wondered when seeing the older tractor ads, for the "All Crop" tractor (UC), if anyone actually has a set mounted up on a UC today? Would anyone have pics?
(Don't mean to hijack Lonnie, just curious)
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 6:34pm
If I can't find any I'll end up redoing my cutoffs. Whoever welded them the first time used 28" rims and welded them with the wrong offset. The hubs are bolted on inside out because the tires hit the final drive when on correctly and inside out it makes the tractor over 8 feet wide. If I redo them I'll use 24" and weld them so the tires are under the fenders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2011 at 9:53pm
I'm guessing these are maybe U wheels since they are flat?
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 12:23am
We have got a set of skeleton on our '31 UC, so yes there are some of them still around. Our '36 has got cutoffs with 24 inch rims on it, which works well, and looks monsterous with 14.9x24 on it.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 9:06am
I have a set of skelton wheels for UC. Will sell. 785-353-2392
Harold (MID MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harold (MID MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 9:17am
I have a UC on skeleton wheels, it is a 1931, serial number 290.  I also have the rings that you put in the skeleton wheels to make them a regular flat steel wheel.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 12:54pm
Lonnie
Those wheels on the pictured UC are WC steel wheels that Roman had torched and drilled to make fit so he could haul the UC on his truck.  I take it your going to that sale?
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2011 at 1:21pm
Jim, no I wasn't going to the auction, I just did a google search and that's one of the pics that came up.
