Fit?
Texas B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas B Quote  Post ReplyReply Direct Link To This Post Topic: Fit?
    Posted: 01 Nov 2011 at 11:20am
Will a C or CA drawbar assembly fit on a B without major modification?
Texas B 39
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 11:24am
The C drawbar is wider. It will not fit unless you swap out the B final drives for C finals. I would think it would take some modification to put a CA drawbar on there.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 11:24am
Depends on what you call major.  C and CA are wider than the B so you would need to cut the drawbar down and re-weld.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 11:32am
Guess I'll have to find out who owns the old machine sitting in the weeds - wider is better and I have an issue with the right final on mine, just have not gotten that far - it has a big CLUNK when taking styarying to move forward.  Kind of makes me think a bearing is gone.
Texas B 39
rickwsomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickwsomd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 1:06pm
When I bought one of my C's the owner thought it was having an issue with the final drive.  It was making a clunking noise when taking off and sometimes when driving.  I got it home and found out that the wheel clamps were loose and were slipping on the rim.  Re-adjusted the eccentrics and tightened everything up and no more clunk.  Just something to check.  Take Care, Rick W.
Rick W.(So.MD)
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2011 at 4:24pm
The C that I used to have clunked the same way because the wheel clamps were loose on one of the wheels.
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
