All crop 60 chain drive
nitehawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nitehawk Quote  Post ReplyReply Direct Link To This Post Topic: All crop 60 chain drive
    Posted: 29 Oct 2011 at 8:07pm
Hello all,
Havn't been here in a while.  Got a problem.  Today I broke a chain on my allcrop 60.  The sprocket is wore very bad.  It is the drive sprocket that goes from the drive shaft with the auger on it under the sieves that drives the clean grain elevator.  Can I fella still get those cast sprockets some where for the detachable link chain, or better yet, has anyone just seen it where it is just converted to a regular roller chain drive setup say using a number 50 or 60 chain.  Seems like it would hold up better on a working machine.  Help, I need to finish combineing my soybeans.
David
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 8:12pm
  it has run this ???/ would repair with original shain  go to salvage yards   will be quiskest an cheapest   my 2 cents
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2011 at 9:55pm
I found cast sprockets online a few years back when I was working on a Case Snapper. In fact I have a brand new one in the shed yet, no hole in the center so you can bore it to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nitehawk Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 5:14pm
What size sprocket is it?  I need one for number 55 flat chain 9 tooth.  You don't remember where you got it from by chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 6:12pm
This was an idler for the gathering chain I think. It was only about 5 tooth. Think I ran 550 roller chain in place of the wore out gathering chain that was on it. Here is one place. http://fcmason.thomasnet.com/viewitems/sprockets/on-stock-bore-sprockets-for-steel-detachable-chain?&sortid=1241&measuresortid=0&sortorder=desc
Here is another outfit that has chain, sprockets, bushings and bearings along with taper lock bushings and more.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2011 at 10:23pm
I would have what you need. 785-353-2392
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 3:54pm
is this the one you need? If so you can have it .
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote nitehawk Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 4:48pm
Thats the one.  Even though it looks wore pretty good I would be happy to get it from you for a spare.  Could you put it in a small priority mail carton and send it to me.
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote nitehawk Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 4:50pm
Sorry Ray for not responding.  Do you have the set, and what kind of shape are they in?
I went to a yard up here this afternoon and found a set that will run a while, but I am keeping my eyes open for a really good set so I have spares.
Thanks David
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2011 at 7:04pm
Hey guys - Try shoupparts.com for the sprocket.  -  AL
