Marvel schebler TSX 470 Carb.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: Marvel schebler TSX 470 Carb.
    Posted: 24 Oct 2011 at 2:08pm
Does anyone have an illustrated schematic they can post up,  the ones in the IT manual are too small.  I am looking for the illustration that shows the carburetor choke cross shaft and all that attaches to it.  Am rebuilding my carb and am missing the cog on the brass shaft that connect to the wire choke control.
Thanks in advance for any help.   Orangeman
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 4:21pm
Here is one from a TSX 486 CA tractor.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 4:32pm
Hello Jeff:  Does the schematic you have show a part name for the following:
1, 2 and 3 and 39, 40 and 41.  I tried to access AGCO parts .com to look up myself but was not able to gain access to the schematic page or narrative listing.
Thanks again Jeff  - appreciate your help!  Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 5:04pm
70225679 1 CARBURETOR ASY. (TSX-486) (Use 70251516)
1 70219996 1 NUT, choke shaft
70909367 1 LOCKWASHER
2 70219968 1 RETAINER, packing choke shaft (ASY. 70225685)
3 70219969 2 PACKING, choke shaft (ASY. 70225685)
4 70219984 1 PLATE ASY., choke
5 70222048 1 GASKET, discharge nozzle (ASY. 70222053, 70225685)
6 70225684 1 NOZZLE, discharge
7 70225681 1 VENTURI
8 70219985 1 FLOAT ASY.
9 70220006 1 JET, idling (ASY. 70225685)
10 70225683 1 JET, econimizer (ASY. 70225685)
11 70224949 1 SEAL, throttle shaft (ASY. 70225685)
12 70219968 1 RETAINER, throttle, shaft seal (ASY. 70225685)
13 70222041 1 SHAFT ASY. (Incl. LEVER and Items 14, 15) (ASY. 70225685)
14 70219977 1 SPRING, throttle stop screw (ASY. 70225685)
15 70222042 1 SCREW, stop throttle lever (ASY. 70225685)
16 70219973 2 SCREW, throttle plate (Incl. LOCKWASHER) (ASY. 70225685)
17 70800465 1 PLUG, throttle body
18 70218872 4 SCREW, fuel bowl to throttle body
19 70225680 1 BODY ASY., throttle (Incl. Items 11 thru 17, 20 & 21)
20 70219971 1 PLATE, throttle
21 70219992 1 PLUG, throttle shaft hole (ASY. 70225685)
22 70219978 1 SPRING, idling adjusting needle
23 70219987 1 NEEDLE, idling adjusting (ASY. 70225685)
24 70219998 1 GASKET, float valve seat (ASY. 70222053, 70225685)
25 70220003 1 VALVE ASY., (Incl. Item 24) (Use 70244912) (ASY. 70225685)
26 70219976 1 GASKET, fuel bowl to throttle body (ASY. 70222053, 70225685)
27 70219986 1 PIN, pivot, float (ASY. 70225685)
28 70219973 2 SCREW, choke plate (Incl. LOCKWASHER)
29 70219975 1 SCREW, choke friction lever
30 70219979 1 SPRING, choke friction lever (ASY. 70225685)
31 70219997 1 WASHER, friction lever screw
32 70219983 1 SHAFT ASY., choke (Incl. LEVER)
33 70225682 1 JET, power (ASY. 70225685)
34 70222038 1 BOWL ASY., fuel (Incl. Items 2, 3 & 36)
35 70224967 1 PLUG, fuel bowl
36 70219967 1 STRAINER, drain, air intake
37 70915514 1 COCK, drain, fuel bowl
70224061 1 PLUG, drain (Supersedes 70222051)
38 70222069 1 SPRING, swivel choke lever
39 70222045 1 SCREW, swivel, choke lever
40 70222044 1 LEVER ASY., choke (Incl. Items 38, 39, & 41)
41 70222046 1 SWIVEL, choke lever
70222053 1 GASKET SET (ASY. 70225685, 70222053)
70225685 1 REPAIR KIT (ASY. 70225685)
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 6:01pm
Wow: thats perfect Jeff.  Thanks so much!  Orangeman.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 8:24pm
Glad to help.
You will find that AGCO will probably not have any of these parts.
I buy alot of parts from Robert's Carburetors.
They are for different Marvel carburetors but alot of the parts will interchange with many different models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 4:17am
Jeff: good to know the Roberts carburetor contact, I will check with VE Petersen as well.  Thanks again - Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2011 at 9:50am
We service and rebuild M/S and Zenith carbs. Have quite a few parts in stock for both. Let me know what parts are needed if interested.
