B/C starter and WC/WD starter differences...
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: B/C starter and WC/WD starter differences...
    Posted: 15 Oct 2011 at 10:13pm
Is the WC/WD starter physically bigger than the B/C starter that it doesn't fit, or is it the ehgaging gear tooth count that is different that does not allow them to be interchanged?
are genuine." - Mark Twain
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 10:26pm
The WD/WD45 starter has 10 teeth on the drive gear and the B/C/CA have 14 teeth.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 10:51pm
I appreciate the quick response, Rick. That's a huge help, thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 7:29am
So, can you change the drive gears around??  Will this work?  Is the cone the same?
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 7:53am
Ted... The starter drive gears can be changed around,but the nose cones have the starter bolt holes in different locations. I'm talking about the hole where the bolt and jamb nut goes. Which starter are you trying to end up with or make? Rick
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 8:11am
Here are some pictures of a C starter and a WD starter nose cone and "inards" side by side.  The C starter is the shiny one and the WD is the rusty one.
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2011 at 9:04am
Well...I thought i had changed them around before,but it's been a long time. According to the pics though,I would say not. Hopefully,I got the tooth count correct on the previous question! LOL!  Rick
This page was generated in 0.107 seconds.
