Tractor Pull tips?
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Topic: Tractor Pull tips?
    Posted: 13 Oct 2011 at 4:23pm
I was at our local show last weekend and decided to pull my WD, I hadn't planned on it and I've never done it before so I wasn't really ready but it was alot of fun and now I want to do it again. Can anybody give me any tips?
I was in the 4000 lb class and weighed in at 3700 so some extra weight will be the first thing as I lost traction. I made it 158 ft and didn't come in last but I want more!
Any pointers would be appreciated.
Pete
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 4:28pm
You have to know what the rules are, seems like each pull has it`s own set of rules.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 4:33pm
Set your drawbar as high and short as allowed. Let air out of you tires so they flatten out a bit and contact more dirt, ? maybe 6-7 lbs.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 4:40pm
If you're going to pull regularly build yourself an adjustable drawbar. Alot of places are 20 inch hitch height but like mine isnt adjustable so I have to change it around for this weekend because the rules at the gas steam and rust show is 18 inch. As CTucker said lower your tire pressure and don't beat on it. Just wind up and ease into it and pull away.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 7:11pm
Ine big mistake i see people making is running in to high of a gear, and getting into the throttle to early and spinning out. 1st gear is going to be your best bet. Yes, I know it's slow, but it gives the tires time to bite. also, leave the snap coupler arms in the "down" position. Don't hit he throttle to fast, bet don't let it pull in idle either. 1st gear, 1/8-1/4 throttle to start out, probably won't need any more than 1/2 throttle
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 7:13pm
used to pull against a Farmall Super H or M that had a sugar cane rear end, had a creeper gear in it, he'd put'er in low gear and walk right out of the arena/barn
German Shepherd dad
#WD234847
#WD88193
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:06pm
As for the gearing situtation, if you have enough power to run in 2nd gear I would.  I pull my WD-45 is 2nd almost always, to get the engine to lug a little, and it will gain all kinds of traction.  I am not saying I am an expert puller, but I can usually put the WD-45 in first place.  As for a rear weight bracket I made one to fit on the lift arms and it seems to work good as it sets the weights back a little making them more effective than being farther ahead on the tractor.  On hard pulling tracks I will run 1, maybe 2 weights on the front.  I pull 4500, and 5000 with it.  Its also got 2 sets of wheel weights on the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2011 at 8:21pm
Those all sound like good tips, I will try them next time. I pulled in first gear because I was told there was a speed limit but nobody seemed to know what it was. I guess I'll have to find out all the rules.
Thanks,
Pete
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 1:51pm
its tricky, but you need to set it per the rules at where you are pulling, take plenty of notes, and just keep experimenting!!! adjust weights and air pressures are your main things to play with. Each time you go to the track, it will be different.
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC,
also own a D-10, D-12, G and a CA.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2011 at 3:47pm
Cheat..................oh, sorry that came out didn't it?  LOL
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2011 at 9:44am
I found the rules and it doesn't look like you can do much except add some weight, and tune it up the best you can. Bolt on weights only, max draw bar height 17", min length 22" from center of axle, everything original or stock replacement . I guess it's just for fun anyway, I just like to do the best I can at what ever I do and try to put the Orange up front.
Pete
