Removing throw bearing???
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Removing throw bearing???
    Posted: 10 Oct 2011 at 8:38pm
I am doing the clutch on my WD45 - how do I reomove the throw bearing.  There appears to be a spirng holding onto the grease nipple.  Do I just unhook the spring?  How do I know which way to put the new bearing on - front to back of bearing?
thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2011 at 8:54pm
Yes remove spring and bearing and carrier will slide off.
  The new bearing goes on with wides flat surface to engine.   MACK
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 5:03am
I'm late with this post, but I have a nice Rebuilt PP [9 spring] and Clutch disc [ rebuilt w/ original NOS AC facings ready to install ] for your 45. PM if you haven't purchased yet.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2011 at 7:17am
Chris has a good point, make sure you use the 9 spring plate, WD's and WC's only had a 6 spring plate and they will fit but won't take the HP
