Convert back to generator, but 12v
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Convert back to generator, but 12v
    Posted: 02 Oct 2011 at 11:04pm
Model C converted to 12v with alternator in the '80's.
I have the alternator's regulator in the toolbox.
The alternator bearings fell apart. I can replace it for
cheap. However, I always felt it didn't look right, sort
of had remorse about doing it.  I have advice from friend
to get replacement alternator for $50 and this time paint
it orange, then it would look right. He also said what's
next, a quest to find stinky leaded gas?  Some people
just don't understand.
Can anyone suggest a 12v generator and alternator
combination?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 12:25am
You should be able to find a 10SI Delco alternator for around $10 now or go to the later style which are smaller and higher output. Or look for a generator off 1955 to 1964 GM car or pick-up to find a 12V generator.
 the 10SI is internally reguated so easy to wire with just one wire and sensing wire from hot lead to one spade on alt. regulator terminals
Edited by Coke-in-MN - 03 Oct 2011 at 12:27am
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 8:12am
lafontaine generator Exchange can rewind a stock gennie for 12 volts.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 8:32am
Using an alternator from a junk auto would probably be the cheapest repair (the 10SI is a good one). These old Allis's don't use much electricity in most cases (most are rarely used at nite, don't have big radios/amps, don't have A/C/heaters/electric cooling fans, etc...and start rather quickly) and a hi ouput alternator is overkill.
I like using the generators from the old Chevys (the short style) when upgrading to 12V; looks original (and installs using the 6V gennie bracket and belt) and it will supply enough power to keep the battery fully charged. I also have the electrical shop run the gennie and balance the regulator to it. To retain the original look and to isolate from the weather, I mount the regulator inside the tool box.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 8:45am
How about a D-17 Generator? I have no idea how much they get for them at the scrap yards but it should look pretty original?
Bud(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bud(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 8:26pm
Late D-14's & D-15's were 12v positive ground and had the same engine family.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2011 at 8:36pm
D-17 genny is too long. I bought one for my D15, but it wouldn't fit in front of the carb.
Bob
