WD45 clutch.....
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 clutch.....
    Posted: 01 Oct 2011 at 8:46pm
Took the bottem cover off the clutch/flywheel housing...found a few pieces of metal. Never had any trouble with it, so I have no Idea how long they've been there. Anything I should wory about? Maybe from the starter? I remember something may have broke on the starter and maybe that was why it was rebuilt? Also noticed a grease zerk in there? does this need to be regularly greased? Thanks
NOTE: PICS BIG FOR MAGNIFICATION
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 9:34pm
I think it would be from the ring gear and starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 9:38pm
Thats what I was thinking.
German Shepherd dad
#WD234847
#WD88193
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 9:46pm
And the zerk would be on the throw-out bearing? If so its good to keep it greased up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 10:20pm
A little goes a long way. Don't want excess to get on the clutch.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 10:46pm
Thanks for adding that Charlie, probably a pump of grease once a year is plenty, if the traactor is used a fair amount one pump twice a year.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2011 at 10:50pm
Yes grease is good but not to much. Thanks for adding that Charlie.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 12:39am
Thanks, I'll probably do the twice a year, it's probably not used anymore than 10 hours a month, but when it is used the clutch gets a work out
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 12:40am
Also, Is there supposed to be a gasket for that cover (the entire thing) I noticed a little oil drip on the bolts (reason I took it off in the first place)
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 7:30am
No gasket, there's nothing to hold in there,it's just a cover to keep crud from getting on your clutch and throwout bearing,
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 9:01pm
from what you are showing in the picture,that is a tooth off of the starter bendix,from a previous injury...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2011 at 9:48pm
That would make sense. I knew something broke in the starter so grandpa had the whole thing rebuilt, this was 3 or 4 years ago, so I couldn't remember what broke. Guess it must have been the bendix.
German Shepherd dad
#WD234847
#WD88193
