D17 Loader? what fits?
dishtech43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dishtech43 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Loader? what fits?
    Posted: 24 Sep 2011 at 12:26am
Hi,I drug an old D17 series 4 out of the woods this summer.that has been sitting for over 15 years.I got the little tractor running pretty good,without alot of work..but I think it has a combine motor in it..it is grey..not for sure..anyway..I want to put a loader on it,but not a new one..too much money for what I need.ha..I have found old ones that was on d17`s,but trip bucket..I want something with two way hydraulics..Looking at an old John deere model 34.but pics look like it is one way hydraulics..Does anyone know what loader will fit the D17..?? thanks guys..
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 12:45am
You can make anything fit you want....just takes some modifying is all
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 6:14am
If it really is a Ser. IV  then you should already have the Live Hydraulic pump on the side and the 2 correct valves for double acting cylinders.
The Allis Model 517 Loader would be the correct loader.
Gary
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 7:15am
I Got a great bend loader off a 170 that fit perfect. Mounts were all the same.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 10:13am
If the motor is grey, it probably IS a 'Gleaner E'.  About as close to a D17 Series IV engine, without being a D17 Series IV engine.  Someone might pipe-up and tell the details.
Yes, you want a full-hydraulic loader.  I'll second Benny's comment, with the note- If you're not a fabricatin' type (with torch, saw, welder, and the ability to do it), it'd be best to find someone who is, as it opens up LOTS of options, and helps keep the cost down.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2011 at 1:10pm
Have a couple loaders that are all hydraulic and could be readily adapted as long as your tractor has dual outlets 563 652-2949
Post Options Post Options   Thanks (0) Thanks(0)   Quote dishtech43 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 11:36am
Ok thanks guys..Allis Model 517 Loader looks like what I need..Yes my d17 is a series 4.and does have the pump, on right side where my others have belt pulley...It will make a great tractor for a loader,im sure..yes I have welder and torch,just havent welded that much in the last 5 years..something I need to keep up with to be good at..ha...Thanks again..
This page was generated in 0.089 seconds.
