1947 c Loud whinning noise in rearend
craigreavley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Topic: 1947 c Loud whinning noise in rearend
    Posted: 23 Sep 2011 at 1:34pm
What would cause a loud whinning noise in the rearend of a C. It makes the noise in all gears, only when tractor is moving. Both sides are evenly loud all fluids are full. If you jack up one side and spin the wheel by hand it is heard as well.Everything works as it should it is just really loud in all gears. I have several Cs and there is always some gear noise but this one tractor is by far excessive. The noise seems to be coming from right at the center of where the two axles go into the center transmission.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 1:58pm
Pinion to ring gear mesh, or bearings on  pinion and differential, or all 6 (4 bearings, two gears).
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 2:06pm
I have another complete transmission and rear end for a c that is good. Is it easier to change rearend, or try to tear this one aprt and fix???
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 2:37pm
My Farmall 504 has sounded like that for more than 10 years. I think it is called wear. So far it is not noticeably worse from one use to the next. Also it is a constant sound, not like broken teeth.
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2011 at 7:31pm
My C has a similar noise. It stops when the clutch is in and everything stops turning. It does it in neutral also but gets worse the higher gear you're in. Third is terrible. I believe mine is in the trans since it does it in neutral.
This page was generated in 0.176 seconds.
