Were some Band C front hubs different?
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Were some Band C front hubs different?
    Posted: 20 Sep 2011 at 8:52am
The 41 C front tires are about 1" apart at the bottom and the CA sitting
next to it has about 2" of space  at the bottom. Were some B and C
hubs different? The hubs assembled normally onto the spindles, but
the 5:00 X 15 new tires rub on the top of the pedestal on the C.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 9:05am
There were several hubs used over the years.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 10:10am
I think your tires are too big.  'C' specs show 4.00 X 15 as the tire size. CA used 5.00 X 15.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2011 at 12:02pm
OK  But a C and a CA NF have the same Spindal Assembly part # 225121. The CA hubs look the same as a C hub but have different part numbers as do the rims themselves. Pretty sure they will interchange though. All the B C CA hubs  use the same bearings and seals. There may be a slight difference in the hub or wheel the offsets but I don't think so.
Alberta Phill  is right on about the tire spec size difference
