WD45 vs CA
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: WD45 vs CA
    Posted: 07 Sep 2011 at 5:29pm
What one do you think is better? Which one has more bang for what it is?
Which one is more of a all around tractor?
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 5:40pm
Why the comparison?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 5:47pm
They were designed for diffferent size farms so you're comparing apples and oranges, as far as which is better. I like the 45 better, but the CA makes a better lawn mower and might be better for plowing small gardens plots. From what I've seen a nice CA can bring about as much as an average 45. So that would make a 45 a better value but give the CA better resale. I still prefer a 45.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 5:52pm
WD 45 Sounds  more manly ....
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 5:53pm
Originally posted by wkpoor wkpoor wrote:
Why the comparison?
Because I want to know if one is more useful than the other, looking for the best tractor to buy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 5:59pm
More power with the 45 ..
more power  you get more uses .
get er done quicker  you git more time with da wife ....
or .   gf ........
 or more time at your favorite waterin hole ?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 6:03pm
What are you going to use if for???  For some things, a 16 oz hammer is the right tool, for other things a 5 lb sledge hammer is better.
Mark
GTH-L Simplicity
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 6:06pm
I can't say what I would use it for. I live on a farm so I would use it for everything I could!
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 6:14pm
Well is it for play or work ? Again .. i,d take the 45 for everyday work , plowin the road , plowing a field , diskin , seeding ,  balein, haulin hay  or bush hogin .
 But if you give me a CA .. i,d take it off your hands ...
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 6:17pm
It won't be a main tractor by any means, I will use it for alot of things, you could call it play insted of work. ;-)
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 6:29pm
just get one of each. then you will know!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 6:41pm
After reading the responses I have a new response. You first need to nail down the intended use and then that will determine which is better for you. One could very easily farm 10-20acres or more with a CA and 2 row implements. Outside of basic jobs for me the WD45 is too small so I have opted for a larger much newer utility tractor that can handle a loader real well and was designed to have one on it and then use the CA for basic stuff it was designed for. So I wouldn't have either for a utility tractor but either would be OK if you keep them inside of their comfort zone.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 6:47pm
Get a 45. Can do all the light work and pull a 3 bottom plow and plus it is arguably the most famous tractor Allis ever built. yep 45. But then it's fun to rake with a tractor like a CA.
Wink
I am a Russian Bot
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 7:00pm
Check out the CA I have in the Classifieds section. I'm a few hours from you. CA's are a pretty healthy little unit to have.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 7:35pm
Raking hay, plowing the garden, mowing the yard, or cultivating with a 2 row front mount, the CA would be great. If you want to plow snow, scoop dirt, bush hog the waterways, plow some bigger patches, or anything where you might need to slip the hand clutch, the 45 is the tool for ya. Also if you want a loader for small odd jobs, the W9 can be had for half what a W8 would for the CA. I think you can buy a 45 in good mechanical shape cheaper than most CA's so you have more bang for your buck with the 45. Buy a 45, you won't be sorry.
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 7:42pm
my vote is a WD or WD45.  With an aftermarket 3 point hitch they can fill in for some of your more modern tractors.  In my opinion CA is gonna be hard pressed to find a place on a modern farm.  You can find things to do, but 90% of the equipment today is larger and heavier than the tractor so just towing the implement could be "unsafe" or break something on the tractor.  The CA live pto seems less robust than the WD system, and if I recall parts aren't as easy to get as the WD clutch.  If you are used to an independent pto of the more modern stuff and you like the modern hydraulics, forget both tractors!  And if you need nice ergonomic and easy mounting platforms (joint/back problems), forget both tractors!  If you want an older AC but want more modern operators station and modern hydraulics, look at the 170/180/190 models.  D-series with factory 3 points and low pressure hydraulics would also be more modern in my mind.
karl f
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 7:53pm
WD45 easier to get on an off plus the oil run hand clutch makes this tractor very easy for young people to operate. Our 3 children all started to drive a WD45 before any other tractor on the farm.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 7:57pm
WKpoor is off, WD-45 is a perfect size tractor.  Plenty of power and agile.  A great utility tractor and overall great value for your money.  CA is just too light and doesn't have a lot of nicer amentities that the WD-45 has.  And finally the CA is a pain in the behind to get on and off of easily.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 7:57pm
This one is very easy. I love to use my "CA" for everything I do. It is small in size but has the HP to get the job done and also has the same hydrualic system as the "WD-45". The "CA" can use some of the snap-coupler equipment made for the "WD" & "WD-45" so some equipment is easy to find. How ever equipment made just for the "CA" gets harder to find.
  Heres why I say it's easy. The "WD-45" weights more,has more HP, easier to find equipment & cost is about the same.
I vote for the "WD-45"
Thanks & God Bless
Dennis
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 9:04pm
WD 45 all the way. Kind of a biased opinion, having never owned just ocasionally run the neighbors CA. But I can tell ya, I love mine. Will love it even more after the hometown pull on friday nite... lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 9:49pm
RW what kind of farm? WD45 would be best for hay and livestock work.
Are you just wanting to own an old Allis? Do you have modern tractors already or are you looking for something to do most of your work?  Why these two models, a D14, D15 or D17 would be better for a working tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2011 at 10:14pm
If I'm right the WD-45 is close to an M or possibly an H Farmall. For yrs my only everyday tractor was an H modified with live hydraulics, Saginaw 3pt, Power top link, Remotes and on and on. But thats a pretty good sized tractor for no more than it can do. Once I got my hands on a newer tractor , JD5400 with 520 loader, I realized trying to use an antique for the everyday stuff was out the door. Now I can sit back and enjoy the antiques for what they were intended and get the job done with the new tractor. I enjoy going to and holding plow ins but this spring when I needed to get a field done to plant my sweet corn I hopped on the Deere. Wow what a difference about 50yrs makes. It didn't seem like work at all. WD-45 is a great tractor but its still an antique. Keep it in prespective and either one will seve you well.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 8:22am
Corn and soybeans and a little hay is what we farm. The reason really is just to own a allis tractor myself like Dave said. I don't really consider the D series because most all of them are out of my price range. And it looks like the WD45 is the way to go!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 8:41am
Now wait a minute. A CA is really fun to tool around on just for the thrill. :')
Wink
I am a Russian Bot
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 9:58am
Another thought is that I have a Farmall Mta with a 3 point and a wd45 is about the same hp and with a 3 point adapter for the 45 I can use the same implements.
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 11:20am
The CA is a nice little tractor, but I would go with a WD or WD45. More power, more things you can do. I plow my garden every year with my WD and Model 53 plow.
One thing my WD does not do well is moving big bales of hay. I have a 3 point bale carrier, and while my tractor has plenty of power (I think it has a 45 crank) it is too light. The front end will come up and then you are steering with the brakes, until the bale drags off the rear.
Not the tractors fault, big bales weren't around when the WD or 45 were designed.
Robert
bhalstead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 4:04pm
get the wd45 it has plutey of power and it is stroger then th m and h
wd45 with 3 bottom plow
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 4:23pm
Ive had both and the CA is gone now, hard little tractor for a old guy to get on and off.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 4:55pm
I have both and if I needed to get rid of one it would be the CA. A WD45 is notmuch bigger but alot more power. handles 3 pt eguipment better. the PTO on A CA is so far off the ground that coman equiopment dosen't wook to well. The CA is better for mowing . thats because I have a woods Belly mower on it. The Hand clutch on the CA is usless compaired to a WD. and WD45s can be had for half the price of a CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2011 at 8:03pm
A 3 pt adapter may be fine for most things, but most don't activate the traction boost system, so plowing with the 3 point , you would be at a disadvantage on the WD45. If you use a Snap couple plow and switch to a 3 point, you will quickly learn the advantages of the SC traction boost system.
