6060 3 Point Lift ???
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Topic: 6060 3 Point Lift ???
    Posted: 17 Aug 2011 at 1:05pm
What would cause the lift on 6060 to be jerky? It does not operate smooth but jerks when you move lever.
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 1:09pm
FIRST thing i would do is change filter ?
Do you know this tractors history ?
meaning did u buy it new  or used ?
Perhaps changing all hydraulic oil is in order ?
its the cheapest place to start
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 1:52pm
bought it used, but the former owner bought it new and was famous for maintaining his equipment. The fluid is very clean. I think I will change the filter and see if that changes anything. Thought there might be an adjustment. Now that I think of it, the hydraulic hookups are jerky and very fast acting also.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 2:08pm
there is a adjustment knob for the hydraulics, maybe this is turned to much one way?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 3:07pm
Where is it located Charlie?
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:35pm
It has cable operated hydraulics like my 6080.  It probably has rust or crud in the linkage.  I'd lubricate it really good then give it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 7:11am
The levers operate smoothly after being lubricated, but the hydraulics seem to operate so quick that it jerks the whole tractor when raising the brush cutter.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 7:47am
The Lift Shaft Sensitivity control lever. I need to get to my parents house to look at the 6060 to take a picture.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 2:56pm
Thanks Charlie,
I appreciate it.
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 10:23pm
the lever (pull up knob) is on the deck to the right rear of the tractor seat
Edited by ky wonder - 18 Aug 2011 at 10:24pm
i like old tractors of all colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2011 at 5:41am
I knew it was there somewhere, just something you never use so I forgot where it was.
Let us know if it resolves your issue.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2011 at 12:56pm
I know what you're talking about. Which would make it react slower, pushed down or pulled up?
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 7:42am
Anyone know???
Allis Chalmers 6060
5' Tiller
5' Box Blade
4' Aerator
60" belly mower
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 7:51am
Just move it to different positions and try it to see what it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2011 at 10:18am
Pull up for less sensitivity, push down for more. I assume yours must be pushed all the way down?
Charlie
