D-15 gas tank level float
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Topic: D-15 gas tank level float
    Posted: 31 Jul 2011 at 6:30am
can you get just the cork float.i no the whole sending unit is not cheap seems that the float doesnt float anymore in the tank.thanks for any info.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 7:29am
I couldn't find a float that would work long term. They all got gas logged and started sinking. I bought one online that actually came from AGCO, but it wasn't like the orginal. It was a little pricey, but it worked. I found one on ebay like the original in the picture after I ordered mine, and they still have one. The link is below, but I have never ordered from them.
Edited by Rogers - 31 Jul 2011 at 7:30am
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 7:58am
I've used a big ordinary cork from the hardware store a couple times. The secret to longevity is coating the float with SealAll, a goo that stands gasoline and alcohol often found in the same hardware store.
Gerald J.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 8:05am
We have complete units that are replacements from AGCO#70227865 D10 thru D15 all series gas or Diesel and #70229188 for D17 series I II III IV gas and Diesel the come with gasket and new screws. Just got 3 of each in yesterday, sold out of the at Hutchinson show. David 734-320-3470   www.djstractorparts.intuitwebsites.com
djstractorparts@ yahoo.com
both run  $90.00 + the ride
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 8:54am
I think it was Charlie that figured out a Model A Ford gas tank float fits as nice as the original.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 8:59am
Call Kevin at Old Standard Auto parts 866-654-2855.  I got a bunch of them in the spring for mine.  As Brain says, they are for a Ford model A and are very nice quality.
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 9:14am
Found a cork at a Hobby Store for my D15 about 5yrs ago, coated it with SealsAll, still working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 9:21am
thanks for all the info the idea with the hardware store cork and seal all sounds great ill try it.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 5:18pm
The float in My D17 was a white hard-foam type 'liberated' from the fuel tank of a mid '90's Suburban...  Junkyard find... $0.25...
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 10:29pm
I get mine from the local car repair shop just ask for a junk fuel pump / sending unit out of a gas tank and cut the float off. Works real nice and there're free.
This page was generated in 0.168 seconds.
