Parts Washer
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Parts Washer
    Posted: 24 Jul 2011 at 9:48pm
If anyone uses a 20 Gallon Harbor Freight Parts Washer to clean their Allis-Chalmers parts, you may be interested in the following eBay item (Not Mine).
The drain plug in the parts washer is M14x1.5.  This Adapter Package will allow you to fit a readily available 1/8 NPT ball valve into the drain plug.  Only the M14x1.5 adapter is needed.
I just did this with my newly purchased el cheapo parts washer.  This adapter did the trick for the cheapest purchase cost + shipping that I could find at that time.
Scott
Edited by Scott(GA) - 24 Jul 2011 at 10:15pm
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 8:26pm
Thanks for the tip, I am going to fit one on mine.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 10:00pm
Good to hear that someone found it useful.
Best regards,
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2011 at 10:15pm
This page was generated in 0.848 seconds.
