K2 Air Flow Grain Saver
Message Reverse Sort Order
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: K2 Air Flow Grain Saver
    Posted: 24 Jul 2011 at 9:05pm
It will not benefit you on level ground. It was meant to somewhat equalize the chaffer load on unlevel ground. It would use a blast of air to attempt to spread the chaff across the whole width of the chaffer. Ryan
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2011 at 8:51pm
I'm in the process of rebuilding my Gleaner K2. I bought a K2 for parts that has an Air Flow Grain Saver on it. I'm considering installing it on my machine. My terrain is mostly flat with some slight slopes. I realize this option was intended for hilly terrain. My question is; Does this option improve the performance of the machine any on flat ground, or would it just be extra weight and power draw.
